Old 01-02-2011, 06:13 PM
key stone's Avatar
Member #10621
What size of trailer do I need
I am planning my trailer build and I need your pictures or ideas I want to make a single axle 14x8 with a ramp on the back with 18'' sides any input would be appreciated
Old 01-04-2011, 12:33 PM
2catchaPredator's Avatar
Member #10644
If i was designing my own trailer i'd make my sides removable.
Old 01-04-2011, 01:33 PM
4getful2's Avatar
Member #1234
Although 8 ft. sounds wide enough , it may not be. My '03 polaris has the old style hubs and can squeeze into a 48" spot, so you could put 2 of those side by side. my buddies '05 is wider and you cannot get two side by side in a 96" pocket. you may want to think about on-off loading from the side and have a 4" high rail on the side , that would be used for cable tie-downs and a stop curb as well.
my two cents
Old 01-04-2011, 02:00 PM
Wolverine's Avatar
Member #7915
I have a landscaper type trailer 5x8. Works great.
Old 01-04-2011, 02:36 PM
cwlongshot's Avatar
We have three machines, opted for a 7x12 with side loading. But its not that great, but it works. Turth be told, its a better trailer for two machines, one side loaded and one rear.
I to will be building another trailer, but it will be a one up, flat bed 5x8'. It means two tow vehicles, but will be better for me overall.
Old 01-04-2011, 04:53 PM
Bionic Man's Avatar
Member #3455
I 2nd the opinion to make the side rails removable. I'm not a fan of riding over the side rails to load the ATV and my wife flat out refuses to do it.
Also, I'd go a little longer than 14'. If you load them on length wise, 14' is the absolute minimum you want. If you mount your spare on the front of the trailer and have a ramp on the back, it is VERY tight to get them both on the trailer.
2010 Sportsman 550 XP
2004 Sportsman 700
Old 01-10-2011, 05:57 PM
stricker76's Avatar
Member #10943
Yeah, if your planning on loading them legthwise then it might be tight depending what machins your hauling. Here's some pics of a trailer i threw together a few years ago. I believe the trailer frame was 14' 2", and i added a piece of 5" square tubing to the back to mount the ramp to. Still had to lay the ramp back a little to get the 500 on the back with bumpers on it. Ended up selling that trailer when i bought the xp cause it was too damn wide to fit on there as the ramp brackets were only 53" wide.
Old 01-10-2011, 06:22 PM
key stone's Avatar
Member #10621
Thanks for the input I have 11 sportsman,9 xp 850,05 800 and 04 600 according to my measurements a 8x14 will just work I plan on having the front rail on a 20 degree angle and yes having the rails removable
Old 01-11-2011, 01:26 AM
Dbez1's Avatar
Member #10159
Hey Stricker, why doesn't your XP fit on a 53" wide trailer? Did you put wider tires on it? (Looks like a nice job on the trailer.)
2011 Sportsman Touring 850 (current)
2006 Outlander 400 (Sold)
2001 Sportsman 500HO (Current)
1997 Explorer 500 (Traded)
1998 Sport 400. (Sold)
1994 Trailblazer. (Sold)
198? Suzuki Quadsport 230. (Sold)
197? Yamaha YZ225 Three-Wheeler (Traded)
Old 01-11-2011, 05:12 AM
mhollerich's Avatar
Member #9741
put sides that hinge down as ramps w/ big pins as hinges so you can remove w/ a hole for the fender spot. just an idea i have a 5x8 aluma with 18 in sides works great.. i dont haul my wheeler much but works good....everyone else uses it and hits dogs and shit wtf
2009 sportsman xp 550
hand and thumb warmers
pure polaris mid windsheild
pure polaris front bursh guard
warn 3500 winch
2006 polaris predator 50cc
2008 polaris scrambler 90cc
best trailer size for a polaris ranger
minimum trailer size for polaris utv
polaris ranger trailer size
polaris utv ranger trailer u-haul
trailer size for polaris ranger
what size 4 wheeler do i need
what size flat bed trailer does one need to haul a polaris ranger
what size of trailer needed for 2 atvs
what size trailer do i need for 2 atvs
what size trailer do i need for a polaris ranger
what size trailer do i need for my new polaris ranger
what size trailer do i need to haul a 2010 polaris ranger 800
what size trailer for a polaris ranger 500
what size trailer for polaris ranger
what size trailer for polaris utv
what size winch do i need for a polaris ranger 500
what trailer weight rating for polaris ranger
will a polari rzr s fit in 5x8 trailer
Small ATV trailer cwlongshot ATV General Discussion 21 02-21-2012 09:41 PM
5x7 used ATV trailer. rfjr1 ATV Purchasing and Price 6 10-24-2010 06:43 PM
Trailer recomendation ttazz ATV General Discussion 9 07-18-2010 10:22 AM
Show us your trailer bukaty Polaris XP 8 05-22-2010 01:48 PM
Trailer Ideas? snopro357 ATV General Discussion 3 04-04-2010 05:25 PM
