Old 05-23-2011, 01:11 PM
iwanna ride's Avatar
Member #15329
please help me
i have problems w my sportsman 500 i recently got it and know less than i wish about it. i removed the carb and cleaned it all. changed all fluids greased etc. brakes you name it,. i repaced the rewind spring and pull rope, when i did i cleaned all rust from the flywheel starter and the other thing in there, stator or magnito? not sure. but i put a little grease on the gears and flywheel only a little mind you. when i tried to start it it would only start when i let off the start button and only after trying it several times. it also backfires sometimes then i hit the start button and let off quick and it will start and run great until 3/4 throttle up. i took the cover off the flywheel and found a milky white slime, prob mix of grease and brake clean ,prob bad for things so i cleaned all and left dry and put back together, still the same!! i also changed the stock air filter w a k&n high flow. what is in w the starter and flywheel? could i have damaged them? and would the air filter cause the bogging at 3/4 to full throttle? pr perhaps the revometer is bad?
Old 05-23-2011, 03:57 PM
utahjaun's Avatar
Member #11470
sounds like the carb is out of whack to me
o8 sprotsman 500
Old 05-23-2011, 04:06 PM
Member #15329
hey well ive taken it off and cleaned it and also taken it back off to ensure the choke and throttle are working right. they looked good. there are no mixture screws just the idle screw. the only prob i know of w it is the drain screw wont stop dripping but the float n needle seem in working order. would the needle valve bein bad do this?
Old 05-23-2011, 04:11 PM
Member #15329
also ran and started after the carb cleaning just not after the rewind spring. i changed the oil and drained in both spots and did not prime the sump. would this do it and wack out compression
utahjaun's Avatar
Member #11470
i think if the needle is bad it will leak
o8 sprotsman 500
Old 05-23-2011, 04:14 PM
Member #15329
yes it will but it shouldnt affect the way it runs should it and prob at idle if at all also the drain screw on the bottom of the bowl seems to be an issue on these and i did try a new screw as well
Old 05-24-2011, 05:01 AM
tt425's Avatar
Member #3687
The needle seat is bad or trash is in the carb. That will cause it to run bad.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again)
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
Old 05-24-2011, 07:39 AM
Member #15329
thanks would that also cause my starting problem because it is leaning out? i thought maybe that was bad cause also leaking gas from the bowl drain and have tried a new screw.
Old 05-24-2011, 07:51 AM
tt425's Avatar
Member #3687
The needle seat is causing all of your problems. Also pull the seat out and make sure the "o" ring is good. I could be worn out(not a sharp point or bad edges) or a small piece of trash in it.
1995 425 4x4 Magnum
Old 05-24-2011, 07:57 AM
Member #15329
okay that sound sensible, thanks!! now just wondering why it ran good after i cleaned the carb and then rode for a little bit then it had trouble starting after i did all the other work? do you think this is just a coincidance ?
1994 polaris 350 backfire
1996 polaris 425 magnum 4x4
polaris 350l bogging
polaris 350l no start backfire
polaris sportsman milky oil
