Old 06-06-2011, 10:03 PM
skizmo's Avatar
Member #13773
rate this GPS unit
I want to buy this GPS.I would like to here from you guys that have it,had it or similar...thanks
Garmin Oregon 450 3" GPS : Outdoor GPS - Best Buy Canada
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
Old 06-07-2011, 12:48 AM
patrolman850's Avatar
Member #6617
Great unit, I have one and it works well. Go's thru battery's fast but oh well. Never left me lost.
Old 06-07-2011, 02:04 AM
Smoothbassman's Avatar
Member #2920
It's a solid unit. A little hard to see in bright daylight. I went with the 62S just for that reason. Same software, better screen for ATV riding.
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 06-07-2011, 06:46 AM
cwlongshot's Avatar
I have read good things!! It was on my short list of units before I found the one I bought used for a great price...
Old 06-07-2011, 12:34 PM
skizmo's Avatar
Member #13773
nice...thanks guys
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 06-08-2011, 03:59 AM
Beenthere's Avatar
Member #2620
GPSmap 60CSx works great for ATVing
95 Magnum 425 4X4
Old 06-08-2011, 11:52 AM
Newfieboy's Avatar
Member #12116
Try a 60csx at half the price of the Oregon.
Costco - Garmin® GPSMAP® 60CSX Handheld GPS System
Old 06-08-2011, 06:37 PM
skizmo's Avatar
Member #13773
I think I am going to stick the the Oregon..I like the 3" touch screen and how you can scroll threw the gps like an I phone..
what did you guys use for a mount....I am looking at this ram mount
RAM Handlebar Rail Mount with Zinc Coated U-Bolt Base & Sealed Enclosure Medium Size Aqua Box
Just would like to here your feed back...
thanks
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 06-09-2011, 04:07 AM
BobT's Avatar
Member #3783
How are you going to use the touch screen with it in an enclosed box?
Boilermaker
2010 850 Touring, ATV-Guru Cobra bumpers
Old 06-09-2011, 11:28 AM
skizmo's Avatar
Member #13773
the ram mount has "flex lens" this feature should allow you would use the touch screen...
Aqua Box Features:
1. A unique, patented all inclusive seal and Flex-Lens. This is really cool stuff!
2. Touch through lens to operate buttons.
3. Power, earphone and accessory cables are routed through a patented, self draining baffledesign to keep moisture out.
4. Fits any RAM Mounting System for use on Planes, Motorcycles, Boats, ATVs, Bikes, etc.
5. Easily locks with any standard mini padlock.
6. All marine grade construction including stainless steel hinge pin and mounting hardware.
7. Flex-Lens may be replaced in seconds if scratched or damaged. (inexpensive)
8. Lifetime Warranty on all components other than Flex-Lens.
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
garmin oregon gps mount to polaris sportsman
oregon 450 gps mounts for polaris atv
powered by vbulletin gps unit
2009 550 XP...... EPS unit nightmare! MoneySpent ATV New Members 7 04-13-2012 11:21 AM
unit will not rev out muddybuddy ATV General Discussion 7 06-07-2011 11:51 AM
How do you rate the stock 11 XP tires? Ronin2 Polaris XP 7 05-22-2011 06:17 AM
How in the He@@ do they rate winches? crimson850 ATV General Discussion 1 10-01-2010 04:13 PM
spring rate chart racer37l Polaris Sportsman 0 09-26-2010 08:19 AM
