Old 06-13-2011, 09:25 PM
radman90's Avatar
Member #15969
2008 Trail Boss Reverse Problems
Trail Boss will not stay in reverse; it makes a grinding noise and jumps out of reverse. When i pull hard on the lever and keep constant pressure it will go in reverse. Thinking the linkage may need adjusted; I removed linkage and put in reverse without linkage but still will not stay in reverse. Runs perfect in forward any ideas?????
Old 06-14-2011, 05:17 AM
Old 08-28-2011, 02:11 PM
Capttaylor03's Avatar
Member #12374
I've got the same problem with my 95 Sportsman 400. Since I don't use reverse all that much, I've been procrastinating in getting it fixed. I have to keep pressure on the stick otherwise it'll jump out of gear. I'd be interested in knowing if it's something to adjust or will I have to take it in.
Old 08-28-2011, 06:40 PM
thomaseweber's Avatar
Member #2655
hmm thats a brain tickler sounds like we need blueline
Hey Ya'll watch this- if i say this i'm getting Stuck.
2004 Ford F350 Lariat 4x4 6.0 Litre FX4
2004 Ford Ranger 4.0ltr 4x4 5spd
2009 Polaris sportsman 850xp
Old 08-28-2011, 10:45 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
the enguagement cogs on the reverse gear are rounding out and should be changed.the more metal shavings that come off the gears the more damage done to the bearings and gears.
01 trail boss reverse
2008 polaris trailboss 330 jumps out of reverse
2008 trail boss
2011 polaris 330 makes noises in reverse
95 polaris trailboss wont go into reverse
polaris 330 pops out of reverse
polaris 330 trail boss reverse gear
polaris atv reverse problems
polaris trail boss 330 grinding noise
polaris trail boss 330 reverse problems
polaris trail boss 330 wont go in gear
polaris trail boss makes grinding sound when put in reverse
polaris trail boss reverse
polaris trailblazer jumping ouy of reverse
reverse is not working on my 2008 polaris trailboss
reverse lever on polaris 330
reverse problems on polaris atvs
trail boss 330 stuck in reverse
trouble getting reverse atv polaris
Trail Boss fan problems? sfrasher ATV Repair and Maintenance 4 04-26-2011 07:49 PM
330 Trail Boss ignition problems MikeA57 ATV Repair and Maintenance 3 01-11-2011 07:51 AM
Problems with spark on 1988 Polaris Trail Boss 250 2 stroke trailboss2x4 ATV Repair and Maintenance 0 10-24-2010 09:38 PM
05 trail blazer reverse problems Ttblksupra ATV Repair and Maintenance 5 07-26-2010 03:45 PM
1987 Polaris Trail Boss 4X4 brake problems xpsfisherman118 ATV Brakes & Suspension 1 03-13-2010 04:59 PM
