Old 07-29-2011, 07:58 PM
racer37l's Avatar
Member #5629
Polaris parts cross reference
Looking for the link that used "Browse" to get to a Polaris site that showed what years and models will interchange. Lost it in changing computers somehow.
Any help will be appreciated. Thanks
Con
Old 07-30-2011, 11:15 AM
racer37l's Avatar
Member #5629
Bump!
Con
Old 07-30-2011, 11:38 AM
ebaysnyper's Avatar
Member #13772
Send a message via Yahoo to ebaysnyper
Bump 2
Sent from my DROID3 using Tapatalk
2007 sportsman 500 x2 efi
26" sadona ripsaws on 12" itp ss312's
3 headlight mod relay type
2500 Ib polaris winch
custom made "winch saver"
custom work light mod with lighted switch and 18 Watt lamps
custom stealth black shock covers
Front trunk locks Polaris Part #2874548 $7.50 each @ dealer
front rack rails converted to "U channel" strut for easy attachments
pure polaris HD front springs
Old 07-30-2011, 03:58 PM
racer37l's Avatar
Member #5629
Just for the record, I finally found the X-reference I thought I lost: http//parts.polarisind.com/Browse/Browse.asp
Everyone enjoy this is very helpful if you're looking for a part and to see if other years and models will fit!!!!
Con
Old 07-30-2011, 04:02 PM
Glad you found it. Wasn't sure cause the one I had been using was on the dealer only site
Old 07-30-2011, 05:15 PM
cwlongshot's Avatar
Can we sticky this??
How about a "stickied" thread where all such useful posts can be found.. Then maybe just a hot link need be added by a admin or mod... Just an idea..
Old 07-30-2011, 07:08 PM
racer37l's Avatar
Member #5629
Yeah, I think this does need to be a "sticky".
Con
atv battery cross reference
atv parts cross referencing
cross reference polaris parts
polaris atv parts cross reference
polaris atv parts crossover numbers
polaris bearing cross reference
polaris cross reference
polaris cross reference for part number 3084940
polaris cross reference for parts
polaris cross reference part numbers
polaris cross reference parts
polaris front bearingscross reference
polaris part 4110189 cross referance
polaris part number cross reference
polaris part number crossover
polaris parts cross reference
polaris parts number cross reference
polaris sportsman 700 cross reference polarisatvforums
polaris winch parts
sportsman 800 cv cross
Polaris Lube---> to Amsoil cross reference guide, does this look right? Bruce! ATV Repair and Maintenance 10 02-18-2012 05:45 AM
John Deere cross-reference Diff part numbers?? primetime1267 Polaris Sportsman 1 07-26-2011 04:35 PM
Rear cross drilled rotor. 7.62Addict ATV General Discussion 3 04-03-2011 06:51 AM
Polaris Lube -->> Amsoil Cross Reference mngatorhunt Polaris XP 6 03-19-2011 05:56 PM
01 sportsman battery cross reference turbocav22 ATV Repair and Maintenance 1 05-10-2010 07:53 AM
