Old 08-01-2011, 07:27 AM
itsfit's Avatar
Member #1726
A/C inop.
the a/c on my father in laws jimmy does not work. It's fully charged and the relay test good. there is power at the compressor, when you push the a/c button on the dash it flashes but the a/c does not turn on. Any ideas? Does anyone have a a/c wiring diagram?
2008 Sportsman 500 HO Polaris winch, front and rear bumbers, rear rack extenter
Old 08-01-2011, 08:10 AM
tt425's Avatar
Member #3687
Is the a/c clutch kicking in? If it's not you can bypass the clutch cylce switch on the accumalator. To do that unplug the switch jump the 2 terminals on the pigtail and if the clutch kicks in the switch is bad. The only other thing is that it's building up to much pressure and the high pressure switch is keeping it from working. Has the orfice tube been changed?
Old 08-01-2011, 09:31 AM
itsfit's Avatar
Member #1726
orfice tube has not been changed, we jumped out the LP swith and it does ingauge the clutch. do you mean the control panal for the climate control? B/C everthing else works like heat and defrost mius a/c for dry air part of the a/c I'll check that orfice tube next thanks for the help!
Old 08-01-2011, 10:14 AM
tt425's Avatar
Member #3687
Clutch cycle switch or low pressure switch same thing. If when you jump that switch the clutch engages 1 of 2 things could be happening. Bad switch or low on freon. It takes about 3 cans of 134a to fill it up with freon. The control panel inside should be good. That switch cost about $15.00. I would try the switch first. Glad to help you.
btw I have been selling auto parts for about 23yrs. I am not an a/c person I am basing that off what I have learned mself and what others have told me.
Old 08-01-2011, 01:55 PM
hatcoleman's Avatar
Member #11479
I agree if you jump out low pressure switch and compressor clutch engages. You have low refrigerant or bad pressure switch. Jump the switch out and run a/c. If it cools good switch is defective. Then replace switch. Should have a schraeder valve fitting so you should not loose your refrigerant. Very common for switch to fail.
ac clutch jump switch low orbad
atv a/c
polaris 2008 sportsman 500 condensation in wiring harness
dash readout inop HOOTER ATV Repair and Maintenance 2 01-28-2011 07:28 PM
Sportsman 400 Fuel Gauge INOP www.FIXMYBIKE.info Polaris Sportsman 6 01-22-2011 07:31 AM
2010 sportsman ho awd inop speedbuff ATV Repair and Maintenance 0 11-15-2010 06:35 PM
2005 sportsman efi 700 engine codes 21 and 42 and 4wd inop hammerhead Polaris Sportsman 0 05-03-2010 04:33 PM
Sportsman 600-AWD inop/Light is on-Please Read!! Dukediggler Polaris Sportsman 5 10-05-2009 03:23 PM
