Good Day All,
So I have recently purchased this 12’ snowmobile / quad trailer. It is a drive-on drive-off design with a slide out loading ramp. It comes with 15” tires, ski tie downs that secure to the deck with wing bolts, rubber sealed lights, front mount jack, stack pockets and rub rails.
I am looking to add my own touch to it. So far I have sanded the rough plywood deck smooth, applied a dura-deck coating and re-installed the deck bolts with washers underneath them to prevent from splitting the plywood. I have installed ½” x ¾” copper pipe couplings in the holes that the wing nuts go through in the deck to prevent damage to the threads and prevent the deck from splintering.
I am looking at installing a wireless back up camera that is installed directly into the bumper and is flush with the rear marker lights. I would run the monitor wires through the trailer next to the trailer wires and have the connections next to the trailer plug. I would then run the wires from my monitor in my truck to the trailer hitch receiver to allow for is hook-up and disconnect. I am also looking at replacing all the rubber sealed lights with LED trailer lights ( If I submerge my trailer so deep my lights get water in them I have bigger issues than worrying about my lights). I was also considering installing a tool box in front of the rock shield, just behind the spare tire mount.
If anyone has any other ideas or suggestions I would like to hear them.
