Old 09-01-2011, 11:25 AM
bgirard420's Avatar
Member #11494
Question Cleaning L&R Cargo Bags
Hey everybody, how do you clean the cargo bags for the rear lock and ride system? I am sure I can take a sponge and some H2O to them, but I was hoping someone had a slick and neat way to clean the mud off without getting them soaked for days. Thanks.
2010 Sportsman 500 H.O.
Old 09-01-2011, 04:28 PM
cwlongshot's Avatar
I use simple green and a hose... Have you tried a stiff brush?
Old 09-01-2011, 04:37 PM
bgirard420's Avatar
Member #11494
This will be my first attempt at cleaning them. I figured somebody had already put some thought into this before me. So I take a brush to get the cake off, then spray some simple green, light scrub and then hose off? How long do they take to dry? Appreciate the advise as I don't want to mess these things up.
Old 09-01-2011, 05:10 PM
BlackSheep5's Avatar
Member #17395
I've been spraying them lightly with a pressure washer for over 3 years now and they are holding up just fine.
Old 09-01-2011, 05:39 PM
cwlongshot's Avatar
Wink
Right, I hit them with the simple green. (Watered down maybe 6oz per gallon)
Then hit it with the wet brush and rince off. Mine dry pretty quickly sitting in the sun.
I have the same ones as you. Works good if you keep up with it...
Old 09-02-2011, 04:03 AM
bgirard420's Avatar
Member #11494
Excellent, thanks! I use a pressure washer on the quad anyway, go to know if I go easy it won't rip the flap off or burn a hole in it!
Old 09-02-2011, 04:38 AM
I clean mine with just soap and a sponge. After cleaning I spray it with Armor All and let it soak until it drys. It look like brand new when its dry.
pure polaris rear l&r box
Trail boss 330 cargo bags Doodle Polaris Trail Boss 3 08-08-2011 04:25 PM
Cleaning Underneath of ATV? TNWB ATV General Discussion 8 07-23-2011 10:22 PM
cargo bags yoteseeker ATV General Discussion 5 10-04-2010 11:15 AM
Cleaning Tips SLxp550 ATV Repair and Maintenance 10 08-10-2010 05:40 PM
Fresh Cleaning Goose Polaris Sportsman 5 04-28-2010 11:56 AM
