Old 12-03-2011, 01:38 PM
jordaman17's Avatar
Member #13240
Thumbs down winch problem
hey guys, i got a 3500 Polaris winch and today i went to use it and found that the out doesn't work only the in. any ideas on what would cause this? ive checked connections at the battery the winch and switch. i believe there are other connections somewhere ?
Old 12-03-2011, 04:28 PM
jordaman17's Avatar
Member #13240
bump.
Old 12-03-2011, 04:41 PM
Zipper's Avatar
Member #10646
did it not work right from the begining.?
mine stops working most times wont come in i figured it just get hot let it sit for a bit then works again. Pain in the butt while plowing snow.!!!
Old 12-03-2011, 04:45 PM
jordaman17's Avatar
Member #13240
the winch has never given me an issue, last time i was out i used it a couple times, then this time there was just nothing...
Old 12-03-2011, 05:38 PM
shui5612's Avatar
Member #19703
might be the button getting dirty inside and not working... happened to me alot of times, just clean it out often or change it to a more waterproof/dustproof one.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 12-03-2011, 05:41 PM
jordaman17's Avatar
Member #13240
i opened it up and it's perfectly clean but i'll see if i can get it to work
Old 12-03-2011, 05:51 PM
shui5612's Avatar
Member #19703
weird.. because the only few times mine was acting up , i opened the button and it was dusty/dirty inside.....
it happened to me some time in the summer and winter, it fixed itself after some time (it happened when it was new really)
or the button fixe did work for me.
hope yours will work/you find out whats wrong...
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 12-03-2011, 05:53 PM
jordaman17's Avatar
Member #13240
yea, maby the contacts in it are dirty but the plastic is very clean. how do i clean it?
Old 12-03-2011, 06:25 PM
shui5612's Avatar
Member #19703
open it up, spray compressed air or clean with alcohol... and qtips..
dont recall how much disassembling had to be done because i made my son do it while i was changeing the tires..
just be sure to reassemble it the correct way...
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 12-03-2011, 07:44 PM
antoniodef's Avatar
Member #11247
It's the contactor I bet. Try reversing the wires at the winch and see if the out works and the in does not.
2011 Trail Boss - HIDs SOLD
atv super winch doesnt work
atv winch issue
atv winch problems
atv winch wont work
how to operate winch on polaris sportsman
polairis winch problems
polaris 2500 winch problems
polaris 500 ho battery winch problem
polaris atv 2500 winch problems
polaris atv winch problems
polaris winch problems
polaris winch stops working then works
polaris winch working in and out
winch installation 08 polaris sportsman 500 ho
winch wont work
winch wont work battery problem
Winch problem remote_medic ATV Repair and Maintenance 2 11-27-2011 01:45 AM
Winch Problem... Aschrades ATV Repair and Maintenance 4 02-13-2011 10:38 AM
Winch Problem Bucky Polaris Sportsman 11 01-26-2011 08:31 PM
winch problem please help stickem ATV General Discussion 6 10-09-2010 02:53 PM
problem wih winch kohen ATV General Discussion 5 05-06-2010 06:52 PM
