Old 12-07-2011, 03:57 PM
Ole Nasty's Avatar
Member #14463
What do yall think of this?
Thinking about building one of these to haul both my atv's in the back of my truck.
Old 12-07-2011, 05:45 PM
SeanE1987's Avatar
Member #16252
I don't really care for it, that's alot of weight that's way to far behind the rear axle
1998 Xplorer 300-Stock
Old 12-07-2011, 06:37 PM
shep's Avatar
Member #20739
that and two quads in the back of the truck seems like alot of weight in the truck
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
Old 12-07-2011, 07:23 PM
MyBoyToy's Avatar
Member #19629
weight isn't so much of an issue, the length of load compared to center of wheels is the issue, just get a trailer much safer and in most areas probably less chance of law getting you for over length compliance...
1996 Sportsman 500--- Old be dependable... starts and runs good, just needs tweaking
ITP 25" XL Mudlites
STI HD2 Matte Black Alloy Wheels
48" Polaris Plow
Old 12-07-2011, 07:51 PM
I'd be fixing the setting the height of that thing by welding a triangular support bar at that 90 degree corner coming out oft he hitch.
Old 12-08-2011, 06:41 AM
OK550Touring's Avatar
Member #20873
It looks like an accident waiting to happen. In my opinion that is far to much weight too far back from the receiver. Buy a trailer and keep your load safe.
Old 12-08-2011, 07:30 AM
psuce's Avatar
Member #17623
How would you fit two in the bed? My 500HO is 83", so two would be 166". Lets say 170" to allow for bumpers/tieing down/etc. Your 8' bed and tailgate would be about 116" surface length. That means to hold the quad you would need it to stick past the end of the tailgate about 54". This would be about 70-80" leverage sticking out from your receiver hitch, let alone being 74" (54" +20" tailgate) from back of truck, which depending on your state would not be legal.
As the others have said, don't do it. Get a trailer.
Old 12-08-2011, 10:47 AM
lost cause's Avatar
Member #9763
Nope. Bad idea.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 12-08-2011, 01:03 PM
cwlongshot's Avatar
Wink
I may not be a Engineer, but I play one at work. The best part of this post is the advice you have gotten about it not being safe as pictured...
It definitely could be made to work, but that design should never have left the drawing board.
Better design would be to build a front tire rest on top/above of the box and be able to close the gate...
Old 12-08-2011, 03:11 PM
Member #20873
If you could design it to split the load between two receivers, than I think that might work. It would definately reduce the twisting effect when hitting bumps, or loading and unloading.
how to get two quads in a longbox
What compression are yall getting in the 525? speedfreek Polaris Outlaw 2 07-29-2011 07:06 PM
What sparkplug are yall runin? speedfreek Polaris Outlaw 1 07-22-2011 05:55 PM
