Old 01-23-2012, 03:23 PM
michael0227's Avatar
Member #22604
Need to know whats up with my xpedition
I have a 2001 xpedition 425 4x4 its running rough just wondering what could be the problom
Old 01-23-2012, 05:12 PM
tt425's Avatar
Member #3687
You might just have some trash or water in the fuel. Drain the float bowl on the carb and see if the fuel is good and clean. It might be best if you remove the carb and clean it. The pilot jet might be stopped up. Make sure air filter is clean and airbox is fully assembled. Change spark plug. Is the camshaft good. Really need more information exactly what type of problem you have. Have you owned this atv for a while or just buy it?
Old 01-23-2012, 06:23 PM
polaris xpedition 425 carburetor
polaris xpedition 425 won't rev up
Xpedition 425 Won't Run kmitchl ATV Repair and Maintenance 7 03-26-2012 03:28 PM
02 xpedition 425 wont rev up BOBANDTOBY ATV Repair and Maintenance 3 08-01-2011 10:37 AM
Who has an Xpedition shank0668 ATV General Discussion 12 04-30-2011 06:47 PM
xpedition 4wd problem 425xpedition ATV Repair and Maintenance 8 03-10-2011 02:29 PM
xpedition 425 cam help? wesfab ATV Repair and Maintenance 4 02-09-2011 12:42 PM
