Old 01-16-2010, 01:16 AM
dodgeram3500's Avatar
Member #2674
Question Too much coolant?
I had to add some anti-freeze to my 09 xp 550, and i was wondering if adding too much is a problem. Thnx
Old 01-16-2010, 12:56 PM
no, your reserve tank has a overflow valve. if you fill it up too full, all that will happen is that as the coolant expands it will drip out of the reserve tank. eventually your machine will get the coolant level back to the proper level, so if its overfull, it will be common the see a puddle of coolant on the ground below the reserve tank after riding it
Old 01-17-2010, 09:00 AM
Member #2674
Question thanks blueline15
THANKS! when im plowing snow there is lots of steam coming out of the rad area, is somthing wrong?
Old 01-17-2010, 12:22 PM
keep in eye on it. continually check the overflow tank to see if it is above the "cold" line or not. if it is still, i wouldnt worry about it until it is below the mark. i might take it a few times before it levels itself out.
just check it before you use it and after when it has cooled down.
could also look to see if you can find out exactly where it is coming from. maybe you have a hole in the line that goes from the radiator to the overflow tank
Old 01-20-2010, 05:24 PM
rar54's Avatar
Member #2768
The same thing happens to my sportsman 500 when plowing snow, it is just the snow spray and mist landing on the hot radiator. No biggie
if coolant tank is too full
is it ok if i put too much radiator fluid in the reserve
put too much coolant in overflow tank
too full antifreeze reserve tank
too much anti freeze in reserve
too much antifreeze in reserve tank
too much coolant in the machine
what happen if you fill up your overflow antifize
what happen when radiator is too filled
what happens if i put to much coolant
what happens if overflow jug is too full
what happens if the overflow tank is too full of antifreeze
what happens if you fill in too much coolant
what happens if you fill your coolant too full
what happens if your coolant reserve tank is too full
what happens too much coolant
what happens when overflow tank is too full
what if you put too much coolant in the reserve
what will happen if the you put too much antifreeze
why is there steam coming from my radiator
