Starting on a dead battery? - Polaris ATV Forum
Old 04-09-2013, 06:46 PM
2Tanks's Avatar
Member #30643
Post Starting on a dead battery?
So I'm in the woods real deep. I shut off my 2012 850 Touring go pee and take a couple of pics and come back to find the battery dead. This is just an example but how could I start her????????????????
No pull start on these I know. Can I put it in gear and push like a bitch?
Thanks for your input!
Old 04-09-2013, 06:50 PM
ChickenHawk's Avatar
Member #27917
If by myself I would grab my whiskey and start walking.
Old 04-09-2013, 07:06 PM
JimmyC's Avatar
Member #23401
Thats definitely a good question. Unfortunately I don't think there is a way to start an XP short of jump starting it. I carry some jumper cables just in case. Hopefully someone would stop by. I don't know if you could push it fast enough to get it started but I'd like to know if anyone has.
2011 Polaris XP 850 X2 LE, Polaris 3500HD Winch, Polaris Deluxe Front Brush Guard, ATV Guru Rear Bumper, Front Lock box, SS312 Wheels and 26" Zilla tires w/slime, Kolpin Fender Flares, Ricochet Ultimate Armor Kit,
2012 Polaris XP 550 EPS, Magnetic Metallic, Polaris 3500HD Winch, Polaris Deluxe Front and Rear Brush Guard, Front Lock box
2011 Polaris Phoenix 200 Red/Black
Old 04-09-2013, 07:23 PM
Can't push start a CVT. Your best bet is to keep the battery in tip top shape. Your second option is to carry a portable boost pack so you can jump yourself. It's why it's best to avoid riding by yourself.
And I you ride by yourself, I'd carry a GPS device like the spot so I coul signal for help via text or email If I was stuck.
Old 04-09-2013, 08:17 PM
Amdforever's Avatar
Member #26260
x2 on what Blueline said. The primary has to be spinning to even pinch the belt. Won't happen with a dead bike...
Best options:
- Always keep her on a maintainer while sitting (not a trickle charger); this will keep the build up of sulfur on the plates at bay...slowly killing it for good
- Buy a better battery when able like an Odyssey
- Carry a boost pack
This topic is especially important for those that live in below freezing temps in the winter since the battery will not have near as many CCAs when its cold. Making it difficult to start. Factor in a poorly maintained battery and you'll be facing what your example is!
Old 04-10-2013, 06:45 AM
afsigma21's Avatar
Member #32522
I carry a small jump box just for that reason. They make some small pretty compact ones. Mine is a Schumacher XP400. $39 on Amazon
________________________________
1998 and 1999 Sportsman 500 4x4 w/EBS
BONE STOCK.
http://i572.photobucket.com/albums/s...ps33eaae7b.jpg
Old 04-10-2013, 09:33 AM
ThorsHammer's Avatar
Member #33549
you've got bigger problems if you've been running for a while and get back on the bike and the battery is dead. If you're any distance into the woods your battery will probably die (your bike as well) before you make it back on the boosted battery. THe problem is the battery isn't getting a charge. If it's a car, your alternator is out (not sure the proper term for the charging systems on the ATV's) and not charging the battery. when a car is running, it's getting it's electrical off the alternator, not the battery. same thing with your bike. once it's running. the electircal power is coming from the charging system. not the battery. the battery really only is used to start the motor. thats why they say to wire your winch into a power source that is only live when the engine is one. This prevents you from draining the battery.
option 2 is you've got a bad battery. but you should be maintaining and monitoring your battery enough to know if it's going bad. Rarely do they just decide to quit working.
Old 04-10-2013, 09:42 AM
jscheel1's Avatar
Member #31272
Buy a dry cell, much better for wheelers. Battery tender at Walmart $29, then you will never have to give it a thought. In bad weather, that could be a dangerous situation.
Old, but still ridin..............
08 Outlaw 525 IRS (Stealth Mods)
06 Sportsman 450
04 Trailblazer 250
91 Suzuki RM 250
09 Kawasaki Vulcan Custom
Old 04-14-2013, 12:58 AM
Rooskey's Avatar
Member #22134
Needless to say, there should be a pull start on these bikes. A battery will go out ten times before the stator does. There just trying to get off cheap. In 2012 there was an option for a pull start on the 400, 500, and 800 models, lol....
2012 Sportsman 550 EPS Bronze Mist
2010 Sportsman 550 X2 Sage Green
2014 Sportsman 90 Sage Green
2006 Grizzly 125 Green
Old 04-14-2013, 05:22 AM
RVS Performance's Avatar
Member #29606
With a little work you could pull the clutch cover and put a rope around the primary and pull start it. In an emergency I guess. Boost pack is definitely going on my list of things to carry to the woods.
2000 polaris sportsman will it pull start with dead battery
atv battery booster pack
how do i jump start my polaris scrambler 850
how to jump start an atv
how to jump start polaris ranger
how to jumpstart a polaris atv
how to start a quad with a dead battery
how to start an atv with a dead battery
how to start atv with dead battery
how to start polaris sportsman 500 with dead battery
polaris 550 dead battery will not run with jump
will a dead battery keep a four wheeler from starting
Battery dead! Bear1959 ATV Repair and Maintenance 3 03-19-2012 06:11 AM
battery went dead taxidermist ATV Repair and Maintenance 5 03-13-2012 06:55 PM
Dead Battery Help kujones79 Polaris Sportsman 2 12-02-2011 06:17 PM
Dead battery Cobb71 ATV Repair and Maintenance 2 05-07-2011 06:04 AM
replaced starter- battery cable still melting conections and dead battery mcmarkrazz Polaris Sportsman 4 09-19-2010 08:20 PM
