More than likely the start button has some corrosion on it. Spray it with contact cleaner. That may help. Using a test light clip it to the hot post on the starter and ground the tip to the frame. Push the start button if it lights up you will know the starter is the problem, if not your problem is the switch or maybe the solenoid. If that solenoid is bad you can put one on there off a lawnmower or a ford product it will work fine. Thanks
