Old 08-26-2010, 01:28 PM
watsmyname's Avatar
Member #6743
Question Any Welding Tips??
I am looking to hopefully make some mods to my go kart or buggy havn't decided yet...i will need to do some cutting and welding so maybe i can get a all in one machine.....if you got any suggestions please let me know...
Old 09-03-2010, 02:53 PM
easydoz1's Avatar
Member #5561
I don't know all in ones. But I have a miller 180 mig and a dewalt grinder. It gets r done.
Old 09-03-2010, 06:01 PM
Manaen's Avatar
Member #6699
practice lots of practice. Don't go too cheap with a welder. Always look at the duty cycle on the unit if it is less then 80% walk the other way. The better welders are either 100% or 90%. Basically the cheaper welders will have a lower duty cycle which means that it will trip it's internal load protection very frequently on heavier welding tasks. This will frustrate the crap out of you when you have to stop and wait for the welder to cool down.
Flux core is great for outdoor windy conditions and cheaper upfront cost. But the wire will be more expensive and the welds will be very splattery and dirty (somewhere between mig and stick). This is easy to learn much like MIG in fact most of these welders can be converted to MIG
MIG is very clean the upfront costs are higher however the cost of wire is much cheaper but you do need to buy the CO2 as well. This is easy to learn however you need to learn how to properly setup the welder (Wire speed, amps, gas pressure etc...)
Stick - very flexible welder, cheaper upfront costs. Sticks are cheap and can be purchased to weld almost any type of metal in almost any situation (if it is an AC/DC unit). Stick is harder to learn upfront, it takes time to master the technique of starting your arc.
TIG - very expensive upfront cost, extremely splatter free neat welds.
there are some great online resources
Old 09-03-2010, 06:23 PM
vitosdraggin's Avatar
Member #6619
a stick welding machine will cut and weld with the right electrodes. i use a lincoln sp 135 mig welder 115 volt, it plugs into household outlet and welds 1/8 inch steel plate perfectly and thinner stuff like bodywork, perfect all around for auto repairs frame and body
05 pred 500,pure polaris slip on,k&n air filter,dynojet kit w 170main,bs bumper,bs nerf bars from a dvx,pro armor skid plates,engine ice
Old 09-03-2010, 08:14 PM
denseleit's Avatar
Member #2441
I would agree with most of what you say, except that most if not all guys working on their own quads or even running small shops can't afford a mig with a duty cycle that high. I have a lincoln 175A mig and a precision tig 185 and a plasma cutter. I build and fabricate alot of stuff, quad and race car stuff. My duty cycle is 30%, I've never shut down on thermal..ever, even welding on high setting for more than 5 of 10 minute intervals. For most guys, stick with a bigger name like Lincoln or miller with atleast a 30% duty cycle, and definately run gas with a 75/25mix and practice alot!!!!
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
Old 09-04-2010, 12:11 PM
Manaen's Avatar
Member #6699
I was mistaken, I went out an looked at my mig and it is 40%, I must have been thinking of my arc (stick) welder which is a Lincoln 225 at 80%.
For those who have smaller class welders an additional cooling fan will keep you welding longer. The key is to keep your coils cool inside the welder.
Old 09-10-2010, 11:36 AM
watsmyname's Avatar
Member #6743
Wink Got My Machine!!!!!
i got my machine and its a killer.......it makes perfect cuts and welds but i just have to work on my skill a lil more but the machine is great check it out
Old 09-10-2010, 04:59 PM
Manaen's Avatar
Member #6699
I don't think I've ever heard of that brand of welder, but it does looks like a very nice setup after looking at thier website. Hopefully it holds up for you. The features look really nice and TIG kicks butt!!
can i arc weld on an atv frame?
dirty mig welds
information on polaris welders
list of stick welding tasks
polaris quad welders
polaris sportsman camshaft weld
polaris welder
polaris welding
pure polaris welds look like crap
stick weld 1/8 inch plate
stick weld atv
stick weld atv frame
stick welding atv frame
weld on polaris frame
weld polaris camshaft
welding atv frame with mig welder
welding atv frames
welding cheap atvs
welding for polaris quads
welding on a quad frame
Cleaning Tips SLxp550 ATV Repair and Maintenance 10 08-10-2010 05:40 PM
Wanted:Tips Tricks etc. or how to hobble home on 3 or less wheels. athacker ATV General Discussion 0 08-03-2010 08:43 AM
Changing the Brakes - Any tips? Soulphire ATV Repair and Maintenance 0 07-17-2010 07:09 PM
Tips for Sportsman 500, Please Help vpblaze Polaris Sportsman 11 06-01-2010 09:02 AM
New To Site Need Some Snow Plowing Tips Leo Porcello ATV New Members 4 01-03-2010 05:12 PM
