Old 09-08-2010, 04:23 PM
buckshot276's Avatar
Member #5717
Send a message via MSN to buckshot276 Send a message via Yahoo to buckshot276
front end shaking on my truck
i hit a mudhole in my truck monday and got stuck. (heres a pic)
now since then, everytime i get over about 40mph, my frontend starts shaking really bad. im sure my tires and rims r ok. so i jus dont have a clue. any ideas guys???
Old 09-08-2010, 06:00 PM
NickS's Avatar
Member #5482
Mud is stuck in wheels. Spray inside wheels from underneath or set a sprinkler under there and let it run for a while. Then go get the front end re-aligned. That will fix it unless you broke something under there
2005 Polaris Sportsman 400 4x4
3 Headlight Mod / 14" ITP SS312 / 26" Maxxis Zilla's / Under Body LED Accent Lights
2010 Decals
Old 09-08-2010, 06:43 PM
mkeddie's Avatar
Member #4866
Send a message via Skype™ to mkeddie
it might be something as easy as the weights got pulled off the rims a unbalanced front tire will make it shake
so clean well(pressure washer works great) check for something bent or broke
if that doesn't fix it then have them balanced
i don't think getting stuck would have thrown it out of alignment unless u were really beating on it
2010 850 XP EPS Stealth Black
from dealer
2500lb. winch (with wireless remote)____60" Glacier® II Plow System with extras___Lock & Ride® Front Cargo Box____Rear Rack Extender___Moose hand and throttle warmers
HID Plug and Play Light Kit for 550/850(www.theatvsuperstore.com) lower lights tinted with 20% window tint (still brighter than stock but not blinding bright)
Front & Rear A-Arm Guards XP550/850 2010(www.theatvsuperstore.com)
28" zillas on stock 14" rims(http://www.4wheelparts.com)_____26" stock tires on itp ss212 14" thanks SNW629
Deluxe Front/Rear Brushguard(http://www.superatv.com/)
3 in 1 Polaris atv hitch from (www.theatvsuperstore.com) might i add it was a gift they sent me just for buying some stuff
Galls® 100W Remote Siren (http://www.galls.com/)
lots of lights
motor cycle radio
(still to come Wes Standard(rear seat and storage), dalton clutch kit, 2 inch lift, stealth snorkel kit if they ever make them for the 2010 )
Old 09-09-2010, 02:02 PM
Member #5717
lol i was beatin on it.... pretty hard. but its been rainin and aint did it since it started raining. so i guess it was just mud
Old 09-22-2010, 01:58 AM
cwlongshot's Avatar
Just saw this now.
Tires show a need for balance at about 40 MPH. So I agree with Mkeddie. Tire balance.
I do allot of off roading in my jeeps. Not mud so much but rocks and they have a very bad habit of pushing those weights around the rim. I got sick and tired of paying 30-50$ for a re balance every time I went wheeling. SO I discovered Centramatics. I spent $200 one last time and will never again need to balance a tire. I have them on both my jeeps. They balance the wheel all by them selves as the vehicle rolls down the road. So in your case a little extra mud in the rims or a pulled off weight make no matter!
Old 09-27-2010, 05:12 PM
hot sauce's Avatar
Member #7278
like all above mentioned proly mud, but a twisted driveshaft isn't out of the relm of possibilities. I twisted mine on a 3/4 ton Chevy back about 10 years ago after getting stuck too, and had the same as you are describing.
2009 Sportsman XP 850 EPS
Stealth Black
Polaris 2500 winch
XP Lock and Ride Front Cargo Box
1993 chevy truck bad front shake around 40 to 50 mph
chevy truck shakes
front end shake at 40 mph
front end shakes at 40 mph
front end shaking on truck
front of truck shakes when i get to 40mph
my car got stuck in mud now my wheels are unaligned
my ranger shakes at 40 mph
my truck shakes at 40 mph
my truck shakes in the front end
polaris atv shakes at 40 mph
polaris shaking in front end
shakes in frount end of truck
the front end of my truck shakes
truck shaking after being stuck in the mud
why does my mud truck shake
why does my truck shake at 40 mph
why does the front end of my truck shake?
why is the front end of my truck shaking
What is the next car/truck your wanting to buy?? Bruce! Around The Garage 43 11-18-2011 10:45 AM
1987 Chevy truck belt squeal blueline15 Around The Garage 16 07-24-2011 06:50 PM
cant get sportsman 800 in truck box bigd_rock ATV General Discussion 14 04-02-2011 02:09 PM
550 - will it fit in my truck with the gate closed?? WilliamBos Polaris XP 14 07-08-2010 12:06 PM
850 on 27's in the back of my truck XTRM-HNTR ATV Wheels & Tires 8 05-07-2010 08:05 PM
