Old 12-20-2010, 02:40 AM
bolt's Avatar
Member #9504
Question Shock Bushings sportsman
I have recently run into a problem, my rear shocks are still good but the lower bushings attaching the shock to the a-arm have had it and I need new ones
does anyone know of a replacement bushing/sleeve that will fit?
I emailed Polaris and this is there response 1:
Thank you for your email. Polaris has found that it is very rare that the shock absorber bushes fail; as a result it is not economic for this bush to be available as a spare part. I can only suggest that you go to a shock absorber supplier to see if they have a bush available this is the same size. Sorry for the inconvenience
Thanks and regards
Lance Whitelock
RESPONSE 2:
Hi unfortunately the bushes and sleeves cannot be purchased separately and the complete shocker has to be purchased.
In the past with other shockers our dealers have been able to purchase automotive rubbers from the likes of Burson or Repco and this may be your only chance.
If you were to take the shocker and mounting bolts to any of these places I am sure they may help.
Thanks and Regards,
Andrew Raper
So I was hoping that someone on this forum had already encountered this problem and solved it.
anyhelp would be appreciated
regards
2001 Polaris Sportsman 4x4 500 HO [A01CH50AB]
Old 12-20-2010, 04:11 AM
Smoothbassman's Avatar
Member #2920
I just saw someone post a solution to this problem last week. They purchased a kit from an auto parts store and shimmed it.
That post is located here:
Front shock play
Good luck!
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 12-20-2010, 09:25 AM
pieguy03's Avatar
Member #6567
I took my shock to a local machine shop and he made me new bushings. They work great and cost nine dollars each.
Old 12-20-2010, 12:44 PM
bolt's Avatar
Member #9504
thanks for the replies.
I will check the local autoparts stores for something that will fit.
or maybe follow up on the artic cat bushings.
and let you know what I find out.
Old 12-28-2010, 03:48 AM
bolt's Avatar
Member #9504
Well I have removed my rear shock to get to the lower bushing, lets say there is nothing left of the plastic feeling bushing except the inner metal tube. so I measured the ring on the shock where the bushing goes it measures 22mm inside diameter the metal tube has dimensions of 16mm outside diameter and an inside diameter of 11mm
So I went to the www.nolathane.com.au and used there bush size search link on the left hand side of the page to find something similar.
what I found was a couple of parts that fit part numbers 45144, (suits ford falcon XK XL XM OR XP MODELS for the front double control arm.) dimensions [23.5 mmOD 16 mmID 26 mmL 3 mmFLANGE
the other part # 47265 suits Nissan commercial patrol g60 [dimensions of bush 22.5 mmOD 16 mmID 32.8 mmL 4.8 mmFLANGE
So even though they are not perfect fits I think they could be made to fit easly enough
I will see if i can buy some of them tomorrow. and see if they fit.
I will also check the upper bushing on the shock aswell.
2001 polaris 500 sportsman rear shock bushings
2001 polaris sportsman 500 ho bushing set front
atv bushings
atv replacement shock bushings
atv rubber rear shock bushing
atv shock absorber bushing
atv shock bushings
homemade atv shock bushings
polaris atv bushings
polaris atv shock bushings
polaris rear shock bushing
polaris shock absorber bushing
polaris shock bushing
polaris shock bushings
polaris sportsman 500 shock bushings
polaris sportsman shock bushing
polaris sportsman shock bushings
rear shock bushing polaris
shock absorber bushing for polaris sportsman
shock bushings for atv
Polaris OEM Crankshaft Bearings,Bushings Fit All Sportsman, Ranger, RZR 600, 700, 800 AddictedUSAF ATV Parts for Sale 12 02-07-2012 03:45 PM
front shock bushings pieguy03 Polaris XP 4 12-09-2010 02:54 PM
Outlaw 525s front shock bushings and sleeve. ncampbell2002 ATV Repair and Maintenance 1 07-18-2010 10:57 AM
2009 sportsman 850 squeaky bushings craigracin15 Polaris Sportsman 13 04-20-2010 03:01 AM
A Arm Bushings 500 Sportsman waynecz Polaris Sportsman 2 10-23-2009 02:38 AM
