Old 01-02-2011, 05:19 AM
jroptop's Avatar
Member #8974
front shock height.............
Just out of curiosity,how far down does the shock sit in the strut tower on a 05 Sp 800?Does it in any way change the ride height in the front by raising the depth of the shock in the tower?
2005 Sportsman 800-handguards,viper 54" plow,headlight mod,hids low and hi,hand warmers,reverse light kit,SS212 rims,bear claw tires
2002 Silverado 2500 HD ext cab 8.1
2002 Corvette convertible triple black
Old 01-02-2011, 05:36 AM
cwlongshot's Avatar
Wink
I don't know that I completely understand your question. What are you trying to do?
If your thinking of not fully seating the strut, I would advise against this. The housing is designed to retain enough of the strut while being strong enough to remain safe. Besides the strut is there for rebound and dampening. It's not there to lift or change or provide ride height. It's the length it is, to work with the springs height and remaining suspension components.
HD springs are available to fix sagging stockers. Lift kits may also do what you want.
Old 01-02-2011, 08:02 AM
jroptop's Avatar
Member #8974
Hey CW,thanks for responding,I think you answered my question...so the shock needs to be completely seated and bottomed out in the strut tower?I was just wondering if the shock is completely bottomed out in the strut tower or there is a certain height exposed of the shock?Im not trying to raise or beef up the front suspension,just wondering how much of the shock is supposed to seat in the strut tower,thanks
Old 01-02-2011, 01:44 PM
jroptop's Avatar
Member #8974
Upon inspection,it is known that the shock should bottom out in the strut tower for install.
Old 01-22-2011, 04:59 PM
wieners1's Avatar
Member #11306
strut cartridge
the MacPherson strut should be inserted completely in the housing or you could bottom the strut and damage it or over extend your suspension and break a cv.
Break the law ride New Jersey-its not the machine its the rider so look out.
2001 sportsman 500 ho,winch,plow,a arm protectors,heated grips,3 light mod,over ride bi passed,4 wheel drive in reverse.
98 honda xr250l
Old 01-25-2011, 05:51 PM
elmerkit's Avatar
Member #3805
I think it really depends of the usage about the height using a stock shock there is a very limited adjustment.
2001 sportsman front springs
2002 polaris shocks
adjust front shocks sportsman
can you adjust the ride height on a 2004 polaris 500 ho
does spring adjustment raise polaris
front strut adjustment on 2011 sportsman atv
how to adjust front suspension on 2004 polaris sportsman
how to adjust rear shocks on 2002 polaris sportsman 700
how to adjust shocks on a 02 polaris sportsman 500 4x4
how to adjust sportsman 800 front shocks
how to adjust the struts on a 2001 polaris sportsman 500
how to install lift on polaris macpherson strut
how to replace front shocks on a polaris
polairs sportsman 500 adjust front shocks
polaris 500 atv front suspension sagging
polaris sportsman how to fix a bent strut tower
polaris sportsman shock tower bent
polaris xp 700 front shocks
ride height adjust outlaw polaris
shocks for 2001 polaris sportsman 500 h.o.
Front shock play Ransom Proctor Polaris XP 6 12-17-2010 06:40 AM
front shock bushings pieguy03 Polaris XP 4 12-09-2010 02:54 PM
Outlaw 525s front shock bushings and sleeve. ncampbell2002 ATV Repair and Maintenance 1 07-18-2010 10:57 AM
Right Front Shock tower for 95 Sportman 500 codym Polaris Sportsman 2 06-20-2010 05:25 PM
Front & rear shock adjustments nmpolaris Polaris XP 6 03-25-2010 10:05 AM
