Old 01-05-2011, 10:29 AM
jackwigam's Avatar
Member #10784
Front end lift 2005 Sportsman HO
Anyone had any luck with raising the front end of sportsman to get more clearance? Purchased larger tires and the fronts are very close to the fenders. Would like more clearance.
Old 01-05-2011, 10:45 AM
Old 01-05-2011, 11:35 AM
jackwigam's Avatar
Member #10784
Thank you
Thank you,
Old 01-05-2011, 11:46 AM
Razorback's Avatar
Member #4649
Have you installed HD springs?
Old 01-05-2011, 11:48 AM
jackwigam's Avatar
Member #10784
No I have not. I am still stock all the way except wheels and tires.
Old 01-05-2011, 01:06 PM
NickS's Avatar
Member #5482
How hard is it to install HD springs, and how high will it raise the front? About 2" without a winch? I'm interested in getting some maybe.
2005 Polaris Sportsman 400 4x4
3 Headlight Mod / 14" ITP SS312 / 26" Maxxis Zilla's / Under Body LED Accent Lights
2010 Decals
Old 01-05-2011, 01:19 PM
WilliamBos's Avatar
Member #5254
Send a message via Skype™ to WilliamBos
What other advantages does this offer??
Thanks,
Will
2004 GMC 1500CC Z71.
Old 01-05-2011, 04:40 PM
racer37l's Avatar
Member #5629
From my experience the only way to truly lift a bike is to put larger tires on the bike. However, to give yourself clearance for your tires, you can do one of two things; lift kit using a spring spacer and shock spacer underneath the strut, or install the hd springs. Either way you will get clearance. I put the lift kit under my bike and with 27" radial tires it still rides close to the stock ride. The hd springs will stiffen up the ride. Good luck with whatever you choose. Con
Con
Old 01-06-2011, 07:19 AM
Razorback's Avatar
Member #4649
HD springs are easy to install with basic tools and a jack. Took me about 45 mins and I didn't even have to use a spring compressor. I could have done it quicker if I'd had a better jack. Just remove the storage box, loosen the top nut using two wrenches. One wrench on the top of the strut rod and another on the nut. Jack up the front end and they should come out of the brackets. Undo the nut that holds the spring retainer. Remove spring, put on new spring, and reassemble in reverse order. Be sure to note where the plastic and rubber spacers go and put them back in the right place. Also, once the struts are loose, be sure not to angle them out too much or you could separate the cv joint.
The advantages are an increased height (varies by model, mine raised up over 2.5 in), better ride, and better/easier steering. I have 27" tires and could easily fit 28s.
Old 01-06-2011, 07:24 AM
Razorback's Avatar
Member #4649
So true. I find it funny that people spend thousands of dollars to put a lift on their truck for "clearance" but without fender trimming, can't put on tires that are large enough to really make a difference. Then they wonder why they get stuck in the same holes that others do. Without bigger tires, the axles and a-arms will still drag the mud/rocks and get hung up.
2004 polaris sportsman 400 lift kit
2005 polaris 800 lift front
2005 polaris 800 sportsman lifted
2005 sportsman 700 front end pics
best front lift for 2004 polaris sportsman
best way to raise front end polaris sportsman
how the fuck do you remove the front spring struts on a 2004 polaris sportsman 500 ho
how to do a front end lift on a sportsman
how to lift 05 sportsman
how to make a lift kit for a 04 sportsman 400
how to remove front storage box on 2005 polaris sportsman 400
polaris 700 how to remove front springs
polaris front end lift kit
polaris sportsman front lift
raising the front end on my 2005 polaris sportsman 700
removing front plastic on 2005 polaris sportsman 400
replace polaris 2005 sportsman front strut
sportsman 500 front spring lift 2005
sportsman 700 lift springs
sportsman clearance gain from hd springs
2005 Sportsman 500 HO Front cv joint ravencat05 ATV Repair and Maintenance 1 11-27-2010 10:34 PM
2005 Sportsman 800 Lift Kit Good Idea? texas2fst ATV Brakes & Suspension 4 10-20-2010 09:53 AM
Lift kits good or Bad?Front only... MUDDIE49 ATV General Discussion 16 12-12-2009 04:46 PM
500 H.O. front lift (level) Project chrisford4x4 Polaris Sportsman 3 11-06-2009 05:38 PM
Looking for front A-arm for 2005 sportsman 700 efi mightywash ATV Parts for Sale 2 07-10-2009 06:21 AM
