01-05-2011, 06:19 PM
Member #6089
Sportsman HD Springs????
hey so i do a lot of plowing with my 06 500HO and some jumping it in the summer, i know the polaris front ends usually sag some but i abuse the heck out of that machine(ive rolled it at least 3 times).
anyways...
i was wondering if anyone has installed the HIGHLIFTER HD front springs on their sportsman and what they thought and how hard they were to install?
1986 TrailBoss 250
2006 Sportsman 500HO Red 26" PXT
2007 Sportsman 500X2 Crimson Red 26" PXT
2010 Sportsman 550XP Red 27" ITP 589s
01-05-2011, 06:48 PM
Member #5482
I'm interested in this also, I'm thinking about getting them instead of a lift for the front.
2005 Polaris Sportsman 400 4x4
3 Headlight Mod / 14" ITP SS312 / 26" Maxxis Zilla's / Under Body LED Accent Lights
2010 Decals
01-05-2011, 07:09 PM
Member #8052
suspension... one of the BEST mods EVARRRRRRRRRRRRR.
seriously though, the two best mods on any machine i've ever owned have been suspension and tires. a couple of the easiest mods out there and they will affect the machine more than anything i can think of...
01-06-2011, 01:54 AM
While not the hilifter springs, I chose the EPI HD springs. But they where WAY EASY!!!!!
Personally I did not even require a spring compressor. YOUR EXPERIENCES COULD VARY!!! The first side took me about 30 minutes, the second less then five!!! as I used the compresser on the first side and did not on the second.
GREAT since the mod!!! Dosent sag with the plow and rides and handles better. But I am a bigger guy at 6' and 230#.
01-06-2011, 03:30 AM
Member #5482
Are there any instructions online of how to install them, i want to see what i'm in for if I get some
2010 Decals
01-06-2011, 04:10 AM
I'm not sure. But it is straight forward. On my '07 I removed the front storage box allowing plenty of access. I set the front on a 5 gal pail with a block of wood. I mounted compressors to opposing sides of the spring and compressed it. Then removed top nut and assessembly from the top of the strut. Then removed the spring and carefully removed compressors. When comparing heights. I saw that thee was no pressure on the assessembly of my machine. So I mounted new spring and removed and installed other side without compressors. Yous could vary so do not just unbolt with out containing the coil spring. They could contain allot of pressure. And releasing them haphazardly could easily hurt someone.
01-06-2011, 04:42 AM
Member #3574
Qiuck question about these springs what is the spring rating between the stock one's and polaris HD, High lifter. and EPI springs. I'm also thinking and about change my springs just want more techinal info about these setups. New Shocks would be the way to go but don't want to spend $600 to $1000 on them.
2010 Polaris Sportsman 850XP EPS
6000K HID'S
3500 Pound Winch
5" KC Apollo Lights modified with 6000K HID'S
Polaris Front and Rear Brush Guards
Pitbull Rocker Tires
Gramin Montana 650T GPS
Glacier II Plow
2000 Yamaha Banshee
FMF Pipes and Silencer
Boost Bottle
K&N Air Filter
Nerf Bars
Hole Shot Tires
01-06-2011, 07:11 AM
Member #4649
The polaris HD springs are 128lb/inch. Don't know what the stock rate is for you, but you can probably look it up on babbitts. It listed the rates for mine.
01-06-2011, 08:23 PM
Member #6089
hey thanks for the input i havent decided what ill do yet but the springs seem to be a great mod
thanx
1986 TrailBoss 250
01-13-2011, 03:50 PM
Member #8064
What about spring spacers that add about 2 inches of pre load to the stock spring. and then you can use the factory adjuster from there. Very cheap on e-bay I cut mine from 2 1/2 " pipe and painted them black. I did have to use a spring compressor that I rented for free at Auto Zone. Then I adjusted my spring to its middle adjustment so its really compressed to about its full stock load but I can make it stiff with the adjuster wrench when needed. Cost was Gas to go to autozone to get spring compressor. No problems and works with stock shocks on my 850 XP touring.
03 polaris sportsman 700 stock springs rate, 2005 polaris 400 sportsman $1,000, 2005 polaris sportsman springs, 2006 polaris atv rear springs, coil springs for polaris 700 sportsman, epi hd springs polaris sportsman, epi hd springs sportsman, how to change front springs on a 2006 sportsman, polaris atv hd progressive suspension springs, polaris atv springs, polaris hd springs, polaris shock 7041761 want hd springs, polaris sportsman epi suspension springs, polaris sportsman hd springs, polaris sportsman shocks, polaris sportsman springs, polaris spring compressor, rear springs 2006 500 polaris atv, sportsman hd springs, stiff shocks for polaris sportsman 400
