Old 01-09-2011, 08:43 PM
Canuck Sportsman's Avatar
Member #10840
Brake bleeding order?
Pertains to a 2008 Sportsman 500 HO EFI.
My question is, I know you are supposed to begin bleeding brakes with the furthest one from the master cylinder, so does that mean the rear brake? And if so, since the rear is actuated by both the hand and foot pedal, which one do I pump to do the bleeding? The service manual isnt very clear on these points.
Old 01-10-2011, 04:53 AM
4getful2's Avatar
Member #1234
the rear brake uses both,foot and hand lever,as you see it has it's own master cylinder and resevoir and you'll notice it has two bleeder screws. Since you are bleeding brakes you may as well do both ,start with the foot brake system first, then do hand brake rear,then front right,.......
Old 01-10-2011, 08:26 AM
Member #10840
Thank you!
Old 01-18-2011, 05:23 PM
elmerkit's Avatar
Member #3805
Also make sure to drain your fluid once a years coz brake fluids do expire.
Old 01-19-2011, 08:28 PM
reinaldo's Avatar
Member #9422
Send a message via MSN to reinaldo
Thanks for the info. I'll keep that in mind.
2000 polaris atv sportsman bleeding rear brakes
bleed brakes on polaris 500 sportsman
bleed rear brakes
bleeding brakes 2000 polaris atv
bleeding polaris sportsman brakes
bleeding rear brakes 2000 sportsman
bleeding the brakes polaris sportsman 500
how bleed atv brakes
how to bleed brakes 335 polaris sportsman
how to bleed polaris magnum brakes
how to bleed sportsman brakes
how to bleed the foot brakes on a polaris sportsman atv
how to bleed the rear brake on a polaris 335 sportsman
polaris brake master bleeding
polaris expedition brake bleeding
polaris sportsman 335 foot brake bleeding?
polaris sportsman 500 hand brakes
polaris sportsman bleed brakes
polaris xpedition brake how to bleed
rear brake atv bleed sportsman
Bleeding Brakes Question smc9696 Polaris Magnum 3 09-22-2010 07:48 AM
brake bleeding xpedition 425 schmity ATV Brakes & Suspension 3 03-25-2010 01:17 AM
Where should I order Polaris Parts From? ipaman ATV General Discussion 3 03-16-2010 04:15 PM
