Old 01-13-2011, 05:00 PM
Canuck Sportsman's Avatar
Member #10840
'08 Sportsman 500 EFI...rear caliper, weird nut size?
Trying to change the pads on my Sportsman rear brake...it seems the hex key bolts that retain the pads are a weird size...smaller than 3/8", bigger than 5/16"...smaller than 10mm, bigger than 8mm. I've been to 3 major hardware stores including HD and couldnt find an in between size at any of them in either metric or SAE.
Am I missing something?
NVM, I managed to shoe-horn a 3/8" hex into one of the bolts which seems to be all I need to remove in order to replace the pads. Strangely it still doesnt seem to fit into the other bolt.
Old 01-13-2011, 10:13 PM
Ghost Rider's Avatar
Member #8854
If its smaller than 10mm but larger than an 8mm, then its probably a 9mm. It seems like an odd size to me, but ive seen several manufacturers start use odd sized bolts and hardware in appliances and other things. I think its an attempt to keep people from trying to fix things them selfs.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Old 01-14-2011, 06:07 AM
Member #1958
Are you sure it's hex or is it torx?
Old 01-20-2011, 05:19 PM
elmerkit's Avatar
Member #3805
Make sure that you use proper tools in very job so you can avoid damages the bolt could be worn out that is why it changed its shape.
caliper pin size polaris 9mm
odd nut size 8mm 9mm
polaris brake caliper torx bolt
polaris rear brake screw size
polaris sportsman 500 rear brake caliper
polaris sportsman rear brake caliper bolts
polaris sportsman rear caliper bolt
sportsman 500 metric
weird nut on brakes
what size alan wrench for polaris atv brakes
2000 sportsman 500 rear brake caliper problem gtl2571 ATV Repair and Maintenance 5 04-05-2011 02:15 PM
HELP!! Rear Caliper stuff4mason Polaris Trail Blazer 1 12-10-2010 06:37 PM
Anyone selling Rear Brake Caliper or Muffler for a 98 Sportsman 500? aameyerrenke ATV Parts for Sale 0 07-29-2010 03:19 PM
rear brake caliper bomberboat ATV Brakes & Suspension 5 07-27-2010 01:18 PM
Rear Caliper shootemup56 ATV Parts for Sale 1 03-22-2010 12:46 PM
