Old 01-13-2011, 09:27 PM
Canuck Sportsman's Avatar
Member #10840
Do you guys resurface your rotors when you change pads?
Just wondering, since its a standard thing to do on autos, but there isnt much meat on atv rotors so not sure how you'd even do this??
Old 01-13-2011, 09:56 PM
Ghost Rider's Avatar
Member #8854
As thin as an ATV rotor is, you would be better off just replacing it, theres just not enough metel there to try and resurface.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Old 01-15-2011, 02:20 PM
Razorback's Avatar
Member #4649
Nope. They'll eventually resurface themselves. If they're that worn, then they need to be replaced.
Old 01-15-2011, 05:18 PM
Chops's Avatar
Member #7796
I've had my 02 for 8 years and never even replaced the pads. With the EBS I hardly use the brakes enough for much wear.
2011 XP 850 EPS Orange Madness
2011 RZR-S Orange Madness
2002 700 Silver/Black
Old 01-18-2011, 05:22 PM
elmerkit's Avatar
Member #3805
It really depends on the condition of the rotor but most of the time i just slap on a new set of pads.
can you turn atv brake discs
can you turn rotors on polaris atv
change pads and resurface rotors
do i have to resurface rotors when i change breaks
do i need to replace rotors on a atv
do you have to get your atv rotors turned
do you need to turn rotors on a atv when replacing brake pads
do you replace the rotor when replacing pads on a atv
how do you change brake pads on polaris atv
how to change rotor on sportsman
how to resurface atv brake rotors
how to resurface atv rotors
how to resurface rotors
replacing rotors
turn atv rotors
what type of brake pad do i need for a polaris 550 atv
when should you resurface the rotors on your brakes
when should you turn turn rotors
where to resurface rotors
how many mi out of a set of pads 4x4camaro ATV Brakes & Suspension 18 10-21-2010 06:32 PM
how do I get the the pads off of the caliper thepopeis1 ATV Brakes & Suspension 4 08-30-2010 06:06 PM
FYI - 850 XP Brake Pads SST4530 ATV Brakes & Suspension 8 02-22-2010 08:20 PM
Brake Rotors country hermit ATV Brakes & Suspension 3 12-18-2009 04:13 PM
