Old 01-23-2011, 04:33 AM
gman's Avatar
Member #11228
700 Sportsman tie rod Adjustment?
Is there an adjustment for the tie rods on my 2003 700? My left front wheel looks like it not in alignment with the rear wheel, it is pointing out. Could something in the suspension be bent.
Old 01-23-2011, 05:56 AM
cookies's Avatar
Member #8052
yes there sure is. lemme know if you need anything clarified or have any questions...
Old 01-23-2011, 06:08 AM
mhollerich's Avatar
Member #9741
best way to chalk the wheels is jack up the front end and with a block or something hold the chalk in one position as you or someone else spins the wheel without turning side to side make your mark it will have a straigh line all the way around to measure from. after doing each wheel let the atv down and roll it back and forth and also bouce to compress suspension back to normal. this should give you the best center mark for your tow
2009 sportsman xp 550
hand and thumb warmers
pure polaris mid windsheild
pure polaris front bursh guard
warn 3500 winch
Old 01-25-2011, 05:53 PM
elmerkit's Avatar
Member #3805
Yup your you can have it adjust in a tire shop with computerized camber and wheel alignments.
Old 01-25-2011, 08:50 PM
cookies's Avatar
Member #8052
the camber is not adjustable.
Old 03-31-2011, 02:59 PM
sman700's Avatar
Member #12597
My 700 is currently in the shop getting new ball joints, A-arm, and tie-rod because my front right wheel was pointing out. Dealer told me there was no adjustment.
2000 polaris sportsman front end alignment
adjust tie rod ends atv
atv tie rod adjutment
front wheel alignment polaris 550
how to adjust alignment on a polaris sportsman
how to adjust end rod for atv
how to adjust polaris tie rods
how to adjust tie rod on atv on polaris
how to align front tires on polaris 700 efi
how to align polaris sportsman front end
how to do front end alignment on 2000 polaris sportsman
polaris 700 sportsman tie rod
polaris 700 wheel alignment
polaris atv adjust tie rod
polaris sportsman 700 front end alignment
polaris sportsman 700 tie rod adjustment
polaris tie rod adjustment
sportsman 500 tie rod adjustment
wheel alignment tie rod ends on a 2000 polaris atv
Sportsman 400 Clutch Adjustment HELP! Tspang80 ATV Repair and Maintenance 10 12-19-2010 03:42 PM
Valve Adjustment maverick11 ATV Repair and Maintenance 3 11-03-2010 03:07 PM
idle adjustment for sportsman 500 dlensing Polaris Sportsman 4 07-06-2010 09:42 AM
Valve Adjustment Bionic Man ATV Repair and Maintenance 0 05-10-2010 07:55 PM
carb adjustment Rich ATV Repair and Maintenance 1 03-07-2010 01:01 PM
