Old 01-23-2011, 07:06 PM
Doty's Avatar
Member #11259
foot brake question
just came back from my first ride on my 08 sportsman 500 and coming down steep hills the back brake didn't do much at all, i was trying to make the rears lock up and i couldn't, so i ended up having to use my brake lever. could this mean i need to replace my rear brakes already?
also wondering if people have ever changed the foot paddle, i found it hard to find sometimes and my boot would get caught in the plastic
Old 01-23-2011, 07:14 PM
No completely normal. Rear brakes on any machine have very little stopping ability. All the weight goes to the front. They also do not want you to lock up the rear tires with the rear brake, because then you lose your steering ability, and you start to slide down the hill without any control on the machine. Its really there to keep the machine from speeding up some, but not stop it. Its normal, it was engineered to be that way.
The front brake lever activates both the front and rear brakes together when you squeeze it. 60% stopping power to the front, 40% to the rear.
I think you would have to do a custom foot pedal to change it. I dont know of any aftermarket company that makes different ones.
Old 01-23-2011, 08:25 PM
cookies's Avatar
Member #8052
mine was kinda sluggish too when i got my machine. topped off the fluid and bled just the foot brake and it'll lock up the rear if i really step on it hard now.
Old 01-24-2011, 04:19 PM
Doty's Avatar
Member #11259
thanks i'll give that a try
Old 01-24-2011, 06:25 PM
bakada's Avatar
Member #2821
I find this kind of interesting. My 08 500 does the same thing. Will kind of slow you but wont lock up the back wheels for nothing. I have been meaning to try to bleed the rear and maybe see if they will adjust up some. The rear brakes on my 04 700 will lock right up if I stomp on them. I kind of think there needs to be a little more from the foot petal than I get.
Old 01-25-2011, 05:54 PM
elmerkit's Avatar
Member #3805
You can also try adjusting its tension before change the brake pads.
adjusting yerf dog brakes
do fourwheelers have a foot brake
do they make foot brakes for four wheelers
foot brake on a polaris quad
foot brake on polaris 4 wheeler
footbrake 04 polaris atv
how do you bleed the back brakes on a polarius four wheeler
how to bleed and adjust yerfdog spiderbox brakes
how to make atv foot brake firm
polaris atv foot brake
polaris quad foot brake
polaris quad foot brake bleed
polaris sportsman 500 foot brake
quad foot break
replacing foot brake on polaris atv
should brake light come on when foot pedal polaris magnum 325
what does it mean wen my fourwheeler wheels are locked and the foot brake is loose
what is the atv foot brake
Rear brake question Billyd Polaris Predator 11 04-06-2011 01:07 PM
auxiliary foot brake problems ericmichael54 Polaris Sportsman 4 03-21-2011 06:23 PM
Brake Question markg502 ATV General Discussion 8 03-31-2010 05:59 PM
installing foot brake Boostedawd91 ATV Brakes & Suspension 3 12-25-2009 09:09 PM
foot brake line jhollen ATV Brakes & Suspension 5 12-04-2009 07:09 PM
