Old 01-30-2011, 05:55 PM
4winds's Avatar
Member #10525
shocks or springs
I just bought 2000 500 sportsman.They had a plow on it. I have taken the plow off It seems to sit low on the front.If ilift the front up it falls back down is this the shocks or the springs thanks
Old 01-31-2011, 09:08 AM
cookies's Avatar
Member #8052
with a machine that old it couldn't hurt to replace both. HD springs will make a huge difference though...
Old 01-31-2011, 12:40 PM
Old 01-31-2011, 03:26 PM
FuntanaS's Avatar
Member #11410
The sagging would be from the springs. Worn shocks will hurt the handling but shouldn't cause it to sag.
Old 01-31-2011, 11:46 PM
Ghost Rider's Avatar
Member #8854
From what ive read here, the weight of the plow tends to make the stock springs sag from the extra weight. So replacing the springs would be a good idea.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Old 02-01-2011, 03:54 AM
Diesel man 03's Avatar
Member #7294
I would have to say the springs are the problem, the weight alone makes them sag after a while.ALSO welcome to the forum.
Old 02-01-2011, 04:17 PM
Vinnie0918's Avatar
Member #4452
+1 replace them with HD springs and you wont believe how much better it will handle, and it will sit with alot more ground clearance.
atv forum
atv shocks and springs
forums on polaris atv shocks
polaris atv shocks and springs
polaris atv shocks, springs
polaris atv springs
polaris atv suspension spring
polaris atv suspension springs
shocks 96 polaris plow
shocks and springs for sportsman
shocks for polaris atv
super atv springs make a difference?
who makes polaris shock springs
turning up springs/shocks on 2010 550 xp Ed H ATV New Members 5 01-03-2011 07:25 AM
WTB shocks! smits64 ATV Parts for Sale 1 09-18-2010 04:20 PM
shocks and springs racer37l ATV Performance Modifications 4 08-22-2010 06:16 AM
MV7 Springs Vinnie0918 ATV Brakes & Suspension 0 06-23-2010 06:02 PM
96 sportsman 500 rear springs & shocks firedude26 ATV Repair and Maintenance 3 11-20-2009 02:12 PM
