Old 01-31-2011, 12:35 PM
Cold_and_Tired's Avatar
Member #11125
Weak Rear Brake
Hey guys, I just bought my Xplorer and noticed that the rear brakes were worn in the rear. I replaced the pads and bled the system. Now the rear brakes are pathetically weak and can hardly begin to slow the bike down.
If I use the single handlebar lever, the rear has plenty of stopping power.
Is there a chance the rear master cylinder is dead?
2000 Xplorer 400
Work/Play Machine
Old 01-31-2011, 02:18 PM
cookies's Avatar
Member #8052
did you bleed both lines?
Old 02-03-2011, 07:28 AM
GAT222's Avatar
Member #6943
Rear Brake Master Cylinder
I need a new rear brake master cyl. Any thoughts on where to get a decent price on one for 2007 sportsman 800
Old 02-03-2011, 05:09 PM
elmerkit's Avatar
Member #3805
Try to bleed both lines and also check the adjustment knob.
Old 02-03-2011, 08:52 PM
Member #11125
Sorry I haven't replied back, I've been swamped with work. It's been a few months since I did the brake job but I'm fairly sure I bled both lines. It's out pushing snow right now but I will take a look at it again this weekend to see if I missed something.
2000 Xplorer 400
Work/Play Machine
Old 03-31-2011, 02:55 PM
sman700's Avatar
Member #12597
Did you bleed the brakes by hand or did you use a vacuum bleeder?
I had an issue with my rear brake using the foot pedal a while back. It was the same type of issue.
After searching on many forums, it seems like it is a bad brake design where if you get some air in the line, it does not bleed out very well. Something to do with the brake line being up higher than the cyclinder.
After trying to bleed by hand several times with no positive results, i tried using a vacuum bleeder and all of a sudden the rear brake works again. ..........
I was suprised on how much air was in the rear brake line.
Hope this helps.
Old 04-01-2011, 04:21 AM
GAT222's Avatar
Member #6943
rear brake
I will certainly give it a try, it's better than buying a new cylinder at 150.00 bucks. Thank you for the reply.
Gat
Old 04-01-2011, 08:26 AM
jjjbluray's Avatar
Member #12554
Please post your results and how you did this... I have a problem with my rear brake as well... Thank you.
Old 04-01-2011, 08:34 AM
GAT222's Avatar
Member #6943
I do know a Polaris Mechanic told be to lock the front brake which I will also try
Old 04-01-2011, 08:36 AM
maverick11's Avatar
Member #3694
There is a ton of information on this topic all over the forum but no real good solution until i saw this thread. I'm gonna use the vacuum bleed. I have also thought of relocating the master cylinder and the res. to see if that gives me more pressure. I don't wanna spend any money on this but I gotta have more brakes for a 700lb machine. This is the only complaint i have with polaris.
03 polaris predator 500 rear brake master cylinder
2000 polaris explorer rear brake fluid
2000 polaris xplorer 400 rear brake master cylinder rebuild
2007 polaris brake job
how to bleed rear brakes on polaris predator
polaris 2000 xplorer rear brake master cylinder problems
polaris 2007 sportsman 800 rear brakes weak
polaris explorer bake fluid
polaris predator 500 master cylinder repair
polaris predator 500 master cylinder swap
polaris scrambler 400 weak rear brakes
polaris scrambler brake problem#gsc.tab
polaris scrambler brakes job
polaris sportsman 800 weak rear brakes
polaris xplorer brakeing problem
polarisscrambler rear brakemastercylinder swap
predator 500 master cylinder upgrade
predator 500 rear caliper has no pressure
quad has weak brakes
rear master cylinder rebuild polaris predator
Rear brake question Billyd Polaris Predator 11 04-06-2011 01:07 PM
Rear Brake Caliper phillipnorton Polaris Predator 9 10-14-2010 06:18 PM
rear brake two as one Around The Garage 6 01-12-2010 01:22 PM
XP 550 rear brake upgrade Mechhell ATV Performance Modifications 2 06-06-2009 07:21 PM
chattering rear brake firedude26 ATV Brakes & Suspension 3 05-21-2009 05:07 PM
