02-05-2011, 06:47 AM
Member #11552
Front supsension squeaking...
On my 2011 sportsman, the front suspension squeaks and makes some awful noise when going over rough terrain...it sounds like bushings more than anything...any tips on where the add some lube to help this stop?? It is very annoying.....
02-05-2011, 08:04 AM
On the grease zerks on the a-arms
02-05-2011, 08:23 AM
Member #5005
yea it just needs to be greased. My 850 did the same thing and I greased it and it stopped
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
02-05-2011, 01:44 PM
Member #11552
Ok...thanks guys. You would think that they would grease these from the factory...
02-05-2011, 01:49 PM
They do....but if your machine was sitting in a crate for a few months, and during transport, some of the grease can "wear out". The dealer should of hit the zerks on your machines PDI inspection before you took it. Also possible they did not. Anyway, just do it every 50 hours when you change your oil.
02-06-2011, 09:41 AM
Member #11552
Well, I washed the wheeler this morning, and dried it off...I greased all of the zerks I could see. 3 on each side of the rear, and just 1 on each side on the front. Squeak is still there. Best I can figure, the strut itself is the culprit. I really don't want to take a can of lube and just go crazy all over the strut...I know that will just attract dust and dirt. Any other suggestions? I really would like to not have to take it back to the dealer for this....
02-07-2011, 05:46 PM
Member #3805
Try to check the rubber bushing also lubricate all moving parts.
02-10-2011, 02:52 PM
Member #8258
Well, after the grease is added it might take a few rides to actuate it around the bushing. I am not sure if the grease track is a straight line or criss crossed in the housing.
Another trick I use is to spray WD40 on the underside of my machine from time to time. It keeps everything looking nice (mud and other slips off easier) and helps eliminate those squeaks. I have some friends that do this with their snowmobiles...even the exhaust (when cool)...and they look great years later. An ounce of prevention....
2011 Sportsman 850 Touring EPS
Boardwalk Blue
Deluxe Brushguards
Viper Max 4000# Winch
02-10-2011, 04:44 PM
Member #11254
^^^agreed, but be careful about spraying the WD40 on the outside surface b/c after a while it will discolor your plastics and take the high sheen off.
11 Sportsman XP 850 EPS Orange - High Lifter 3" lift w/pro series axles, 31" Outlaws, KFI 3000# winch, ATV-Guru's front and rear (mine), custom exhaust, 1" spacers x4.
10 RZR 4 - CATVOS 3" lift, 30" Sbacks, 1" Super ATV spacers x4, Front/Rear Popo bumpers, #4500 lb Viper winch, Maier Hood Scoop, Head Ache Net, Fully Snorkeled (hers)
02 Suzuki Vinson - a few goodies (sons)
Previous Rides
08 RZR
07 Can Am 800 xt
02-10-2011, 07:09 PM
Member #11552
That all makes sense guys. I spoke to the service department where I bought it...they told me to turn the springs on the strut a quarter turn, and see what that does...
atv shock squeaks, atv suspension squeak, fix four wheeler squeak, fixing a squeaky four wheeler, four wheeler sqweek, front shocks squeaking on polaris sportsmans, how t ofix squeky atv bushings, how to eliminate squeaky shocks on atv, how to fix squeaky shocks atv, how to fix squeaky shocks on atv, how to fix squeking rzr, polaris rzr spring squeak stop, rzr 4 shocks squeaking, rzr s suspension squeak, rzr sqeaking shock, rzr suspension squeaking, squeaking atv shocks, squeaking suspension on rzr4, squeaky front end on rzr, squeaky shocks on rzr
