02-07-2011, 09:28 AM
Member #11238
HD Front Springs?
I tried this on a different thread and didn't get any response, but maybe this is a more appropriate place for it.
Anyone know where I can get heavy duty front springs for my 2010 X2 550? I can't seem to find any online and the front end seems a little soft, plus I plan on adding a plow next year. Without the HD springs, I am sceptical about adding the plow. Thanks.
Duffer
2010 Sportsman X2 550 EFI
Polaris 2500 Winch
Pure Polaris Deluxe Front Brush Guard & Rear Bumper
JamStraight LED taillights
02-07-2011, 11:58 AM
Member #11694
install spring 7043499-067, also run tires harder, crank up preload on springs, and use preload spacers. these springs are heavier than your stock ones.
i agree they should make some that are even stiffer than those.
you can find them by part number at our website Hit-The-Gas New and Used OEM Parts for Polaris, Yamaha, Suzuki, Kawasaki, ATV, Jet Ski, Motorcycle, Ranger, and Dirt Bike
Check out www.hit-the-gas.com for cheap Polaris OEM parts, Service kits, Tune up kits, and Repair kits.
LONG LIVE THE POLARIS CYCLONE 250!
02-07-2011, 12:15 PM
Member #11238
Thanks for the reply. Do you know what the rating on these are compared to the stock springs?
Duffer
Polaris 2500 Winch
02-07-2011, 02:33 PM
Member #6220
Duffer,
I have a 2010 X2 550 and noticed that with the Glacier III plow I get about an inch or two of sag when I lift it. I haven't tried cranking up my pre-load yet like Hit-the-Gas suggests but I think it would help. My pre-load is set to the second setting on all fours corners now. I had a forum photo album showing the set-up but it got deleted somehow and I was told it can't be recovered so sorry no pictures.
As far as the spring rate differences the spring descriptions look like this:
Stock - SPRING-COMP,184-270,DUAL D,BLK (7043618-067)
Hit-the-Gas recommendation - SPRING-COMP,210#/IN.,BLK (7043499-067)
I'm not sure but it looks like the stock is a dual rate spring with a pretty soft 184lbs. first stage and the recommended replacement is a spring off the 2009 XP that has a single rate of 210lbs. If that's the case then maybe you can find someone here that uses a plow with their 2009 XP 550 to tell you how they like it.
-Jerry
2010 Polaris X2 550
ATV-Guru Cobra bumpers, Polaris front and rear A-Arm protectors, heated hand and thumb grips, 3500lb winch, hand guards, gun scabbard, 3" passenger foot risers, Glacier III plow, HID Lights, Tiger Tail, 9" Windshield
02-07-2011, 03:03 PM
Member #11238
Thanks for the response. I am a total newbie to this and I could not find in the owners manual how to adjust the pre-load. I have the spanner wrench that came with the machine, I'd like to adjust because the front end just feels a little soft. Which way do I turn the wrench when I get it on to stiffen them up? Does the machine need to be off the ground? This is my first machine and I'm a little nervous about screwing something up on it, and I know nothing about how to do it.
Duffer
Polaris 2500 Winch
02-07-2011, 04:18 PM
Member #6220
No worries. I don't think you can hurt anything and you'll be surprised how much tuning your suspension improves the handling. It's easy to reset them if you decide the ride is still too soft or stiff after a few test rides. If I remember correctly there are 5 different settings or notches in the adjustment collar. You can set the front pair and rear pair differently but you should ALWAYS set the front two shocks the same and the rear two shocks the same. So front-to-rear can be different but side-to-side should be the same.
To change the settings the first thing to do is get the tire on the corner you are adjusting off the ground. I just use a floor jack under the skid plate to take the load off the front two tires or rear two tires at the same time. Don't jack up on the suspension A-frame. You won't be taking the load off the suspension and you can damage the A-frame. Next get the spanner wrench on the pre-load adjustment collar and turn it to the right. You should be able to see how the spanner wrench fits around the collar with the spanner "tooth" fitting into one of the small square holes around the perimeter of the collar. If your quad is new it should turn pretty easy. If you feel like your putting a lot of muscle into and not getting anywhere take a step back make sure you aren't already at the maximum setting and turning the wrong way. Or if you've been in a lot of mud sometimes it will get under the adjustment collar and make it harder to turn. If that's the case try a couple squirts of penetrating oil. Just remember that compressing the spring is the same as increasing the pre-load. The worst part of the whole process for me was having to remove the right rear tire because I didn't have enough room to turn the spanner wrench once I got it on. If you have to take the tire off don't forget to torque the wheel lug-nuts back to the correct specifications. I still have the stock steel wheels and they are supposed to be torqued to 45 ft. lbs. (61 Nm).
My pre-load came set at the lowest setting. That is when the spring is compressed the least. I now have it set to the second notch at all four shocks which works pretty good for my riding style and weight. It still seems a little soft in the front with the plow though. I am going to try bumping the front pre-load up to notch three or four the next time I have the plow on. Then set it back to position two when I take the plow off. The good news is the front shocks are the easiest to adjust because they're more accessible.
Good Luck
2010 Polaris X2 550
02-07-2011, 05:44 PM
Member #3805
just a question is the shock also interchangeable?
02-07-2011, 06:26 PM
Member #6220
I believe it is. The Polaris Parts site shows the exact same part number (7043464) for the front shocks on the 2010 X2 550 and the 2009 XP 550. Polaris Parts
The 2009 XP 550 shows two different springs available. I'm guessing one is the HD model that Hit-the-Gas mentioned and the other is the regular?
2010 Polaris X2 550
02-07-2011, 07:02 PM
Member #11238
Thanks a lot Jerry, that info is very helpful. I always get nervous working on a new piece of equipment but this should be pretty simple. It was the same way with my boat a few years ago, and now I wrench on everything with that. I just need a little time to warm up to working on it. I'll give this a try tomorrow. Thanks again.
Duffer
Polaris 2500 Winch
02-08-2011, 05:14 AM
Member #11694
let us know how this works out for ya
2010 polaris 550 xp front spring, 2010 polaris 550 xp front springs, 2010 polaris sportsman spings#gsc.tab, adjusting suspension on polaris 550xp, front springs for polaris atv, hd replacemant front springs sportsman xp, installing struts front polaris, polaris 400 front spring, polaris atv front spring 7042301-067, polaris atv front springs, polaris hd spring rate, polaris hd spring rates, polaris part number 7043499-067, polaris sportsman stock front spring weight, sportsman 550 hd springs, sportsman xp 550 hd springs, sportsman xp hd plow springs, sportsman xp hd spring for plowing, sportsman xp plow spings, xp 550 hd springs
