I just put on HD springs. I was as careful as I could be, but I am still nervous it I pulled the strut out to far. I jacked it up high, but made sure the side I was working on never had the tire lift off the ground. I only pulled it far enough away to work the spring out.
How did you guys know you pulled out to far? Did the axle just fall out? Mine is all buttoned back up. Wheels spin fine, although I can hear my brakes scraping my rotors a little. My axles have about a 1/4" play if you tug them to and from the tire, no play up and down. I went for a ride around the yard for a minute and seems fine, I floored it in the snow to try and get the AWD to engage to see if I could hear any noises. The thing has less than 20 hours so it is so damn squeaky you can't hear shit.
2011 Trail Boss - HIDs SOLD
