Old 02-15-2011, 01:16 PM
04Silverado's Avatar
Member #803
Cool Rear brake not working
Went riding sunday and suddenly I have no rear brakes. Checked the fluid and it was full. Tried bleeding line from hand brake and foot brake, fluid came out but not pressurized like it should be. When I push on the foot brake it goes all the way to the floorboard with no resistance. Hand brake feels normal but front brake works fine but even the hand brake can't make the rear brake work. not sure what to do next. Someone told me to adjust the pads on the rear but they are seated ride on the disc. Any help???
Old 02-15-2011, 05:49 PM
elmerkit's Avatar
Member #3805
You might what to check the brake master it could be worn out.
Old 02-15-2011, 06:50 PM
denseleit's Avatar
Member #2441
ummmmmm what kind of quad????
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
Old 02-16-2011, 04:21 AM
PK_FIREMAN's Avatar
Member #12081
Same problem
I have the same problem with my 06 700 sportsman. My rear brake is working with the hand brake though. I'm thinking there may be a linkage problem somewhere associated with the foot pedal. I'm going to take a closer look this weekend. Does anyone have any ideas what this problem may be? I've got to get this fixed because if I'm holding a beer I don't have any brakes.
Old 02-16-2011, 05:10 AM
The seal in the master cylinder for the rear pedal is likely hard and cracked inside, and the master cylinder must be replaced as it's not rebuildable
Old 02-16-2011, 05:19 AM
PK_FIREMAN's Avatar
Member #12081
Thanks for the reply. What you say sounds right, thats what an automobile would do with a bad master cylinder. Is there any way to check for this or is will it be obvious when I tear into it. I want to make sure thats the problem before I order the part.
Old 02-16-2011, 02:30 PM
Member #803
06 sportsman 800
Old 02-16-2011, 03:30 PM
PK_FIREMAN's Avatar
Member #12081
You say your back brake are not working, even with the hand brake?
Old 02-16-2011, 06:27 PM
Member #803
rear brake doesn't work by using hand or foot brake
Old 02-16-2011, 06:28 PM
^^^ohh, that changes the answer then. I would wonder if the piston inside the caliper is seized up.
05 polaris 800 rear brakes not working
are polaris rear master cylinders rebuildable
atv rear brake not working
atv rear brakes not working
back brakes not working atv not use
do i have to push the foot brake to use the rear brakes on polaris atv
front brakes on polaris sportsman seized
not using back brakes
olaris sportsman rear brake not working
polaris 700 rear brake not working
polaris atv brakes not working
polaris atv rear brake does not work
polaris foot brake not working
polaris predator 500 rear brakes barely working
polaris rear brake problem
polaris rear brakes problem
polaris sportsman fixing foot brake
polaris sportsman rear brake
polaris xp850 brake bleeding
rear brakes not working on atv
Rear brake not working 04Silverado ATV Repair and Maintenance 1 03-18-2011 04:48 PM
2006 800 rear brake not working 04Silverado Polaris Sportsman 1 02-15-2011 01:38 PM
Rear Brake Caliper phillipnorton Polaris Predator 9 10-14-2010 06:18 PM
rear brake two as one Around The Garage 6 01-12-2010 01:22 PM
XP 550 rear brake upgrade Mechhell ATV Performance Modifications 2 06-06-2009 07:21 PM
