02-17-2011, 07:12 PM
Member #12018
Which rear shocks will interchange with early trailboss?
Actually I have a 1985 Polaris 3-wheeler but its the same as the early trailboss's (85-88 for sure, probably newer).
My rear shock is a bit bouncy. I don't want to spend a lot so I'm looking at buying used on ebay. So my question is what newer model rear shocks will interchange? I'd like to go with about as new as possible since I'll probably have a better chance of getting a good one.
Here's one from a 1999 325 Trailboss.
1999 Polaris Trail Boss 325 Rear Shock - eBay (item 190501872109 end time Feb-20-11 15:05:09 PST)
Here's one from a 400L.
Polaris 400L 2x4 Rear Shock - eBay (item 260710427094 end time Feb-18-11 06:08:34 PST)
Will either or both of these work?
2004 Harley Davidson FLHRSI
2003 TRX400EX
2000 XR50R
1997 XR70R
1996 XR100R
1985 ATC350X
1985 ATC250R
1985 Polaris Scrambler 3
1985 YTZ250 TRI-Z
1985 KXT250 - Red Tecate
1984 ATC250R
1984 XR500R
1984 ATC70 X3
1982 XL500R X3
1980 John Deere Liquifire 440
1976 TT500 X3
1975 XL70 X3
1972 SL70 X3
1972 Harley Davidson FX Shovelhead
1970 CT70(H) X5
02-18-2011, 12:03 AM
Member #4649
Go to an online parts site like babbittsonline and look up the part number for your shock. Then run a search for that part number. That'll list every model it's used on.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
02-18-2011, 05:21 AM
Member #12018
I tried that with service honda before starting this thread but when a part is obsolete they don't list the number. I had not heard of babbits so I just checked that out. For the 1985 Trailboss/Scrambler they list the whole shock/spring assmebly as one part number. When I go newer each peice is seperate so I'm comparing apples and oranges. Even if this would have worked out I'm guessing the part numbers would be different even if the shocks would interchange. What I mean by that is I'm sure between 1985 and 2000 some minor change to the shock would have been made such as an updated seal, better bushings etc. And I'm guessing one change such as these would result in a different part number even though the shocks would still basically be the same.
2003 TRX400EX
2000 XR50R
1997 XR70R
1996 XR100R
1985 ATC350X
1985 ATC250R
1985 YTZ250 TRI-Z
1984 ATC250R
1984 XR500R
1984 ATC70 X3
1982 XL500R X3
1976 TT500 X3
1975 XL70 X3
1972 SL70 X3
1970 CT70(H) X5
02-18-2011, 05:47 AM
Member #12018
OK, I just tried what you said about seaching by part number. It does list a part number for the hydraulic portion of the shock for all years so I went with comparing that.
The number for my machine is 7041156, it says it fits 85/86 Scrambler and 85-87 Trailboss. It is obsolete.
But if I go up to 88 Trailboss I get 7041207, which is 1988 only.
If I go up to 1989 I get 7041218 which is subsituted by 7041448. The 2 number combined list to fit just about everything from 1989 to 1998. I went even newer and get a similar story.
I'm hoping someone knows what fits from experience.
If someone knew if the rear shock from a 2000 Trailboss would fit a 1987 Trailboss that would be great.
2003 TRX400EX
2000 XR50R
1997 XR70R
1996 XR100R
1985 ATC350X
1985 ATC250R
1985 YTZ250 TRI-Z
1984 ATC250R
1984 XR500R
1984 ATC70 X3
1982 XL500R X3
1976 TT500 X3
1975 XL70 X3
1972 SL70 X3
1970 CT70(H) X5
02-18-2011, 08:59 AM
Member #4649
PM blueline15 with your part number. He works at a dealer and can probably look up the superseded numbers for you. That way there won't be any confusion about whether a newer version would fit or not.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
02-19-2011, 05:01 AM
Member #12018
Thanks for the heads up, I send him a PM.
Through this ebay acution I found that a 1996 Magnum has a 16 inch shock and the part number is 7041447. My shock is 13 inch so that will not work.
REAR SHOCK 1996 POLARIS MAGNUM 4X4, SUSPENSION - eBay (item 290525722250 end time Feb-20-11 14:27:44 PST)
I believe part number 7041448 is what I need since it fits Trail Boss 1989 through 1999 and a bunch of other models. I just need to figure out what the measurement on that shock is to be sure. I found some on ebay and asked the sellers so hopefully I hear back from someone.
2003 TRX400EX
2000 XR50R
1997 XR70R
1996 XR100R
1985 ATC350X
1985 ATC250R
1985 YTZ250 TRI-Z
1984 ATC250R
1984 XR500R
1984 ATC70 X3
1982 XL500R X3
1976 TT500 X3
1975 XL70 X3
1972 SL70 X3
1970 CT70(H) X5
02-19-2011, 05:15 AM
Member #3687
I have a 92 Trailboss 350 4x4 that I am parting out. The rear shock is bad but I will give you some measurements this weekend. I will have to take it off. I need to finish stripping it down and make a trip to the scrap yard with it.
I also have a rear shock off a 1995 400 xplorer 4x4 that is bad. I will check it out also.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
02-19-2011, 05:21 AM
Member #12018
The measurements would be great! Thanks, I really appriciate it!
2003 TRX400EX
2000 XR50R
1997 XR70R
1996 XR100R
1985 ATC350X
1985 ATC250R
1985 YTZ250 TRI-Z
1984 ATC250R
1984 XR500R
1984 ATC70 X3
1982 XL500R X3
1976 TT500 X3
1975 XL70 X3
1972 SL70 X3
1970 CT70(H) X5
02-19-2011, 12:06 PM
Member #8052
which machine are you trying to replace the springs on? or is it the shock you need to replace? im a little confused by your post. what exactly do you need for what machine?
02-19-2011, 03:15 PM
Im sorry Blown331, I cant get dimensions of the various shocks. Its just not something Polaris gives real accurately. I think your best bet is to shot around the years you have been, and just ask for a measurement on each potential shock. is that 13" with the shock off of the bike?
1985 polaris trail boss front shocks, 1997 polaris sport 400 rear shock fit a 1996 polaris magnum 425?, 2000 polaris trail boss 250 rear shock bushing, 2000 polaris trail boss rear shock, 2003 polaris trail boss rear shock bushing, fox racing shocks for 1985 polaris trail boss atv, polaris 1988 trail boss 250 shock, polaris trail boss shock, polaris trailboss shock, rear shock for polaris trale boss 350, rear shock polaris trail boss, shock for a 2000 xr70r, shock for polaris trailboss 250, what did trail boss do, what is the part number for polaris scrambler shock, what is the proper size shock for a 2000 polaris trail boss, what polaris parts will interchange with 350 trail boss, what size shocks are on a 92 bayou 4 wheeler, will polaris scrambler shocks fit other, xplorer 250 4x4 rear shocks
