Old 02-20-2011, 11:09 AM
jandj's Avatar
Member #12027
Looking for spanner wrench for rear shocks
I'm looking for a place to get a wrench for my rear shock adjustment thought I saw a link somewhere on hear but can't seem to find it again
Old 02-20-2011, 11:13 AM
cwlongshot's Avatar
I g0t mine on eBay!
Old 02-20-2011, 12:49 PM
Just use a large channel wrench. That works perfeclty.
Old 02-20-2011, 07:51 PM
glngib's Avatar
Member #9495
Send a message via AIM to glngib Send a message via Yahoo to glngib
My salesman said it is easier to adjust if you remove the rear wheel?
2011 Polaris Sportsman 400 HO
Polaris front storage compartment (like the 500's)
Polaris 2500 winch
Polaris deluxe brush guard front and rear
Mad Dog 3-way hitch (hitch pin hole interfers with trailer tongue)
Polaris Glacier III snow plow with a rubber wear blade
Polaris rear rack extender
Old 02-21-2011, 04:26 AM
Member #1958
Just recently got this one on ebay. It uses a 3/8 ratchet to turn, works great and reasonably priced.
Shock Spanner Pre-Load Wrench Dirtbike ATV Motorcycle - eBay (item 120636251505 end time Mar-18-11 19:39:44 PDT)
Old 02-21-2011, 12:17 PM
willysrule's Avatar
Member #11810
many adjustable spanners will work too...and it is easier if the quad is off the ground, minimum weight on the spring then...taking the tire off just gives you more room to work..
06 Sportsman 800 EFI LE
06 Ram 3500 Cummins 6-spd
81 Jeep CJ7
some other toys...
Old 02-21-2011, 02:13 PM
Razorback's Avatar
Member #4649
You can find one at most atv/motorcycle accessories dealers under the tools section. I know that dennis kirk and jp cycles has them. I just use the one that came in the toolkit with my motorcycle.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 02-21-2011, 05:17 PM
elmerkit's Avatar
Member #3805
There are a lot of posting at ebay you might want to check it out.
Old 02-21-2011, 05:30 PM
MNPolaris850XPeps's Avatar
Member #11395
i second the channel wrench if u have one i also jack mine up when adjusting works alot better imo
POLARIS 850 XP W/EPS pure polaris hand guards and front lock and ride box, RICOCHET front and rear a-arm gaurds all lifted up on 27" GBC SPARTICUS tires on ITP system 6 rims, uni air filter and fender flares on the way
2000 polaris spring wrench
polaris 800 spanner wrench
polaris atv rear shock wrench
polaris atv spanner wrench
polaris ranger spanner wrench
polaris shock spanner
polaris shock spanner wrench
polaris shock wrench
polaris spanner
polaris spanner shock wrench
polaris spanner wrench
polaris sportsman 800 spanner wrench
polaris suspension wrench
shock spanner wrench polaris
spanner for polaris atv
spanner wrench for polaris shocks
spanner wrench for shocks on atv
spanner wrench polaris shocks
utv shock adjusting wrench
Which rear shocks will interchange with early trailboss? Blown 331 ATV Brakes & Suspension 11 02-20-2011 04:19 PM
Sportsman front and rear shocks jroptop ATV Parts for Sale 0 12-31-2010 12:31 PM
f/s sportsman rear shocks jroptop ATV Parts for Sale 3 12-19-2010 11:02 AM
WTB '06 Outlaw rear shocks psullivan ATV Parts for Sale 2 12-03-2010 09:34 AM
96 sportsman 500 rear springs & shocks firedude26 ATV Repair and Maintenance 3 11-20-2009 02:12 PM
