Old 02-23-2011, 08:15 AM
poboy's Avatar
Member #12121
There must be a secret....
Sportsmen Mechanics:
Trying to remove and replace the front long bushings in my 2000 Sportsmen 500....
I can loosen the front bolt, but then the shaft inside the control arm will spin when I try to loosen the rear bolt. I can tighten the front bolt, then loosen the rear bolt but then the front bolt will not loosen for the same reason.
I see no way to loosen both bolts or prevent the shaft from spinning inside the grease.
Seems it will be easy to replace the bushings and insert and tighten the bolts but there must be some secret way to remove them in the first place....
Thanks for your time and sorry if this has been covered before.
Poboy in Yuma
Old 02-23-2011, 08:41 AM
Nitro's Avatar
Member #8438
Here is whats in my 2002 sportsman manual.
A-ARM REPLACEMENT
1. Elevate and safely support vehicle with weight removed from front wheel(s).
2. Remove cotter pin from ball joint stud at wheel end of A-arm and loosen nut until it is flush with end of stud.
3. Using a soft facehammer, tap nut to loosenA-armfrom bolt. Remove nut andA-armfromhub strut assembly.
4. Loosen two bolts on A-arm tube by alternating each about 1/3 of the way until A-arm can be removed.
5. Examine A-arm shaft. Replace if worn. Discard hardware
2002 Sportsman 400
Old 02-23-2011, 08:45 AM
Nitro's Avatar
Member #8438
You will need to keep a wrench or socket on the other end when removing either bolt. Take your time and you'll get it. Took me some time to get mine off when I had a broken spacer, bent arm and bent shaft.
2002 Sportsman 400
Old 02-23-2011, 08:47 AM
Nitro's Avatar
Member #8438
When re-installing Torque new bolts to 30 ft. lbs. (41.4 Nm).
Tighten ball joint nut to 25 ft. lbs. (35 Nm). If cotter pin holes are not aligned, tighten nut slightly to align.
2002 Sportsman 400
Old 02-23-2011, 08:48 AM
scottdeet's Avatar
Member #7044
I just replied to a post regarding this.
But upon looking closer, instead of "lowering" the A-Arm, maybe RAISE or
pull out either the Front or Back end first.
A-Arm Removal
Take care,
Scott Deeter
Old 02-23-2011, 09:02 AM
Nitro's Avatar
Member #8438
The key is to not removing either bolt all the way before backing the other one out & holding the opposite side when loosening the other. Do it in steps, start with the front or back. Hold the other bolt from moving with a wench. Back it out a little then switch to the other bolt. Repeat until they are both out.
2002 Sportsman 400
Old 02-23-2011, 10:18 AM
poboy's Avatar
Member #12121
Hey Okay! Gotter with the alternating ends trick.
Here's what I had to do.... Because both bolts were really tight, I loosened one bolt and remove it, then wirebrushed the bottom threads, oiled the threads and replaced the bolt. I had to tighten it just tight enough to be able to loosen and remove the other bolt and clean it similarly. I replaced the second bolt and tightened just enough to break the first bolt loose again. It took some dancing back and forth but finally I was able to get both bolts loose at the same time. Then it was a couple of turns to each bolt alternately. Even then, the last few threads of the second bolt were a problem because the shaft inside kept spinning. I inserted a screwdriver into the hole of the removed bolt and I was then able to hold the shaft a bit by prying with the screwdriver while I turned the remaining bolt the last little bit. As I suspected, the shaft was worn and I'll have to replace it and the bushings on both sides.
Now, on to my second problem which is similar.... I removed the cotter pin on the ball joint but when trying to remove the nut on the bottom of the ball joint, the threaded shaft just spins inside the strut housing and I'm unable to remove the nut. Is it the same idea to apply prying pressure to hold the shaft so I can remove the nut? After I removed the two bolts and the retaining plate you'd think the ball joint would just slip out but it will only move about one quarter of an inch and even with gentle persuasion, I cant get the ball joint out. Do I need a bigger hammer? Or is there another secret?
Thanks again to all who contributed.
Poboy in Yuma
Old 02-23-2011, 12:13 PM
Nitro's Avatar
Member #8438
Mine ball joint castle nut came off easily so I don't know. Maybe try tightening it first, then try to loosen it?
2002 Sportsman 400
Old 02-23-2011, 01:31 PM
scottdeet's Avatar
Member #7044
poboy,
Are you replacing the complete A-Arm or just the shaft & bushings?
If just the Shaft & Bushings, can't you just do that part with swinging
out the A-Arm attached to the ball joint and just replace the shaft &
bushings and reinstall the bolts.
Sorry I'm not a typer and have been working on this reply with scans of
instructions of how to remove the Ball Joint but this concerns the removal
of the nut first. Guess we need to know if the threads are messed up first
on the ball joint for removal of the nut. If they are, then I believe that
will become a project with more involved and screwing up the original
Ball Joint.
Take care,
Scott Deeter
Old 02-23-2011, 05:25 PM
elmerkit's Avatar
Member #3805
Great tips Nitro a friend of mine is also having hard time on doing this.
atv ball joint nut wont tighten
best way to get atv ball joint in
cant get ball joint tight on atv
how do you remove a ball joint from an atv
how to get the lower ball joint out of the strut polaris
how to pull ball joint in polaris
how to remove ball joint from polaris strut
how to remove ball joint in polaris atv
how to remove broken polaris ball joint
how to tighten a ball joint bolt on a atv
how to tighten ball joint on atv
loosening the control arm from the ball joint polaris sportsman
polaris 2002 swing arm bushing replacerment
polaris 500 scrambler front control arm bushing removal
polaris a-arm bolt
polaris front a arm removal
polaris rear control arm removal replacement
polaris sportsman front a arm bushing replacement
polaris sportsman front strut ball joint replcemeny
remove cotter pin secret
Secret document reveals obama considering 13 million acre land grab ATVs Today.net ATV General Discussion 0 02-21-2010 07:59 PM
