Old 03-04-2011, 07:40 AM
montanajjc's Avatar
Member #12611
04 Sportsman 500 shifting hard
I have a 04 that I use for plowing and it started to get real hard to shift out of low. This happens most all of the time when plowing now. I have made sure the idle is below 1000rpm but it still shifts hard. I usually have to shut off the engine to get it to shift out of low. Does anyone know of this problem and what I can do to fix it please?
Old 03-04-2011, 08:22 AM
Old 03-04-2011, 01:51 PM
bakada's Avatar
Member #2821
I would start by replacing your belt. While you have the cover off clean the clutches and make sure you don't have any grooves worn in the sheaves/ramps. Make sure that your motor mounts are tight and that the transmission is tight so that the clutches are lining up properly. If it came on gradually I would bet it is the belt. My 700 did the same thing. I noticed when plowing that when I went to put it in reverse out of low it came out of low hard. It gradually got worse. It always shifted smoothly with the engine shut off. Some times if I popped it into neutral before I came to a complete stop it would slip out easily but if I waited until stopped then I felt like I was breaking something trying to get it out of gear. The new belt cured this. My old belt looked good. No chunks or serious wear but it was 3 going on 4 years old.
Old 03-04-2011, 02:06 PM
montanajjc's Avatar
Member #12611
Thank you for the advice, that makes perfect sense. And this is the original belt -6 years old so is likely to be soft and chewed up. Thanks again.
Old 03-04-2011, 03:28 PM
bakada's Avatar
Member #2821
Let us know if it works. I for one was sceptical when I recieved the advice I passed along to you. My belt looked good. It wasnt.
Old 03-06-2011, 05:08 PM
elmerkit's Avatar
Member #3805
I would also suggest to inspect you drive belt for a start.
Old 03-09-2011, 06:31 AM
montanajjc's Avatar
Member #12611
Thank you for the feedback bakada and elmerkit. I replaced the belt and it is shifiting much better. The belt looked supprisingly good for 6 years old but it was thinner and cracked.
Old 03-09-2011, 08:16 AM
bakada's Avatar
Member #2821
Good deal that sure beats the alternative of new clutches or trying to get your old clutches aligned.
Old 03-10-2011, 08:39 AM
bslatt81's Avatar
Member #12820
My 2006 sportsman 600 was doing the same, it would shift fine when the machine was turned off but not when running. I took the clutch cover off and removed the belt. The clutches seemed to be clean but I blew them out with some compressed air and there was lots of dust also used some brake cleaner to clean everything up. After putting it back together it shifts like new again. I guess just that little bit of dust and dirt effects the clutches and doesnt fully disengage so you can shift.
2000 500 sportsman shifts hard
2006 sportsman 500 efi auto hard to shift
2008 sportsman hard to shift
efi polaris sportsman 500 hard to shift
fix hard shifting polaris sportsman 700 atv
polaris 500 hard to shift
polaris 500 shifting
polaris 500 shifting hard
polaris 500 sportsman hard to shift
polaris atv 500 sportsman stiff shifting
polaris sporstman 500 shifts hard
polaris sportsman 500 hard shifter
polaris sportsman 500 shift problem
polaris sportsman 500 shifter
should my sportsman 500 be hard to shift
sportsman 500 ho shifts hard
sportsman 500 shifting problems
sportsman 500 shifts hard
500 sportsman shifting issues mikgro ATV Repair and Maintenance 7 01-17-2011 03:18 PM
Sportsman 600 hard shifting lockmin Polaris Sportsman 4 12-11-2010 04:24 PM
Fast Idle/hard shifting Beeguy ATV General Discussion 10 09-26-2010 03:50 PM
Shifting on an '07 Sportsman 800 djlinton ATV Repair and Maintenance 0 08-03-2010 03:29 PM
shifting problem, 1994 Sportsman jim k ATV Repair and Maintenance 4 07-27-2010 08:01 AM
