03-05-2011, 01:27 PM
Member #7982
trail boss front brake master cylinder
Here's a good question for you...I was messin around with my sons 1990 trilboss... i pulled the brake lever and snapped where it bolts to the master cylinder...great! now I have to replace the master cylinder because that is all cast as one piece......Does it really matter what polaris i get a front brake master cylinder from?...are the brake line diameters and threads standard on polaris? are the handlbar dias standard ( or close enough) on polaris?
03-05-2011, 04:29 PM
I don't see why that would make a proprietary master cylinder for the Trail Boss. SO I agree that its quite probable another model will fit and do the job.
If that doesn't work, I have had very good luck with Babbitt's. http://www.babbittsonline.com/
03-06-2011, 05:09 PM
Member #3805
As long as the brake master is polaris and has the serial number its completely bolt on.
02 polaris trail boss 325 rear master cylinder, 250 polaris trail boss master cylinder, atv master cylinder rebuild kit, front brake master cylinder polaris 325 trail boss, how do i replace brake pads on a 1989 polaris trail boss, how rebuild polaris master cylinder, how to rebuild a master cylinder on polaris trail boss, how to rebuild front hand brake master cylinder polaris, how to rebuild master brake polaris, how to rebuild master cylinder polaris trail boss, polaris 250 trail boss master cylinder, polaris atv master cylinder rebuild kit, polaris front brake master cylinder, polaris master cylinder, polaris master cylinder rebuild kit, polaris trail boss 250 master cylinder rebuild kit, polaris trail boss brake line theead, polaris trail boss master cylinder, rebuilding brake master cylinder polaris, trail boss front brake master cylinder
