Old 03-08-2011, 12:08 PM
vryder1964's Avatar
Member #12726
Help...need to remove brake pads
I am changing my front brake pads on sportsman 700...how do I get the pads out of the calipers?? Looks like the are no bolts...just 2 guide pins...anyone know?
Old 03-08-2011, 08:14 PM
3 Polaris Atvs's Avatar
Member #1102
You unbolt the bracket from the spindle. Remove bracket and caliper. Remove the allen screw from end of of one pin. Slide that pin and remove pads.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
03 polaris 700 how to change brakes
2000 polaris trailblazer 250 how remove front brake shoes
how to change brake pads on polaris sportsman 700
how to change brakes on a 2001 polaris sportsman 500
how to change front brake pads on 2000 polaris 500 sportsman
how to change front brake pads on polaris ranger
how to change front brakes on a polaris 500
how to change rear pads on polaris ranger
how to change sportsman front brake pads
how to install brake pads on p0laris atv
how to remove brake pads on 01 polaris sportsman 500 ho
how to remove front brake caliper from 2012 polaris ranger
how to replace front brakes sportsman
how to replace polaris 500 brake pads
how to replace polaris quad front brake pads
instructions replacing polaris ranger 400 brake pads
polaris scrambler 500 brake pad instructions
polaris sportsman 500 front brake caliper removal
replace front brakes on polaris 500 atv
replace polaris front brake pads
Sportsman Brake Pads bristol399 ATV Brakes & Suspension 15 03-04-2011 04:06 PM
Brake Pads and Rotors Dialtone74 ATV Brakes & Suspension 9 02-09-2011 03:53 AM
After market brake pads kling2001 ATV Brakes & Suspension 7 10-30-2010 02:22 PM
FYI - 850 XP Brake Pads SST4530 ATV Brakes & Suspension 8 02-22-2010 08:20 PM
replacing brake pads sligster ATV New Members 1 10-26-2009 06:09 PM
