03-08-2011, 03:13 PM
Member #9881
Help me adjust the toe of my 400 scrambler
How do I adjust the toe on my Polaris 400 scrambler, it is a 2000 model year. the top of my tires are toed in to far.
03-08-2011, 08:11 PM
Member #1102
You mean the front are toed in? Top being in is camber not toe.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
03-08-2011, 08:32 PM
Member #6542
3PA is right. Craig, take a look at this link and tell us about the problem.
Suspension Tech: What is Caster / Camber / Toe?
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
03-09-2011, 04:29 AM
Member #9881
The problem is the tires lean in to far likes this / not quite that bad but you get the idea. The top of the tires lean in to far and I want to fix it because my Polaris could ride better.
03-09-2011, 04:32 AM
Member #9881
To much negative camber, Do you know how to fix this problem? I would appreciate any help.
03-09-2011, 07:47 AM
Member #11907
There really isn't a way to adjust the camber with Macpherson struts. If your front suspension is sagging (worn springs and/or struts), that could cause your tires to be like this /---\ instead of |---|
2004 polaris 500 scrambler toe adjustment, 250 polaris toe, adjusting shock polaris scrambler, atv toe adjustment, camber and castor on 400 polaris, how do i adjust the rear shock on a 2000 scrambler, how do you adjust a toe and camber on a 1995 polaris 400, how do you adjust the rear shock on a polaris trailblazer, how do you adjust tow on atv, how to align the front of my polaris, is there a way to tighten the chain on my 2000 polaris 400 scrabler, is there a way to tighten the chain on my polaris scrabler, polaris 400 toe, polaris scrambler toe, polaris trail blazer 250 aline front tires, polaris trailblazer 250 toe setting, polaris xp 850 adjusting tow, scrambler adjust rear brake, trail blazer 250 camber, trailblazer 250 toe in
