I have been looking for hd springs and I came across a thread where someone suggested part#2876153 for a guy with a 2002 sportsman. I have a 99 sportsman and was wandering if these will work or should I just go with the EPI springs part#wes321450. The polaris ones have a higher spring rate and can be found cheaper so I would like to go with those if I can. Thank you.
I put the ones out of an 800 in the front of my 500 sportsman they worked but were stiff as hell ...my 06 800 i used polaris h.d springs in front and epi in the rear worked well..
I too am looking into front springs for my sporty (01 model). But according to epi's site the 321450 are for 96-01 and 01-04 and the other spring number you mentioned were for 05 and up. EPI lists a different p/n for the 05 and up , so I would not go with the "other number"
