Old 03-15-2011, 07:29 PM
antoniodef's Avatar
Member #11247
2011 SP spring install Q's
I ordered some HD springs (and rear rack extender) today for my 2011 Sportsman 500. I have a plow set up, and it lowers the front quite a bit. I also am a big guy, 6'2" and 255lb. I am not a fan how much the front dips when I turn. The rear shocks were on the softest setting, so I just stiffened those one setting. Quite a few people said they like the handling with the HD springs, so I wanted to give them a try.
Has anyone changed the front springs on a 2011 Sportsman 400/500/800? I know the 2011's seem to have a different front. I just removed the whole front plastic body piece. The tops of the spring sit up inside/underneath the body piece. There seemed to be no way to access the bolt without removing it.
The frame piece the springs sit against on the top is cupped around the top of the spring. I read where everyone seemed to be able to change the springs without compressing them, I am just wondering if that is possible? Can you compress them by hand enough to get out from underneath the cup?
I also read to be careful of the CV joints. What am I watching out for? Only pull the spring away from the machine far enough to lift the spring off and put the new one on? Do I need to remove the tires? If so, why? They don't seem to be in the way. Do you torque the nut on top of the spring? What to? If so, how would I torque it seeing how I have to use an open ended wrench to get it off since I have to hold the top of the shock while I turn the nut?
I have searched all over here and the internet, but I can't seem to find any good how-to with pics.
I work on all my toys and can usually do anything, I just am a little lost.
Any pointers?
2011 Trail Boss - HIDs SOLD
Old 03-15-2011, 07:34 PM
antoniodef's Avatar
Member #11247
Dang, just found a thread from another forum that shows it pretty well...
Polaris HD Springs Installed - ATVConnection.com ATV Enthusiast Community
Old 03-15-2011, 08:16 PM
scottdeet's Avatar
Member #7044
WOW, 5 mins between posts. Your a quick searcher
I believe the jack-up is used to help relieve pressure from the springs
and also so the axles don't fall out.
Take care,
Scott Deeter
Old 03-16-2011, 06:23 AM
antoniodef's Avatar
Member #11247
It is ironic. I had been looking for hours. Whenever I look for something I always end up reading and learning about similar stuff as I go through links. After looking throughout the day I decided to post. As I closed my browser I saw a tab I had opened and hadn't checked out. It turned out to be that one.
Old 03-18-2011, 11:07 PM
Razorback's Avatar
Member #4649
Yep, it's pretty simple. The springs just sit on those "cups". Jack it up high enough and they'll fall right out. Remove the nuts with it sitting on the ground though. It's easier b/c the weight of the front suspension isn't pulling down on them.
The cv joints: once it's all loose and jacked up, don't pull to far outward on the strut, it can separate the cv joints. Doesn't break anything, but it's a pita b/c you have to disassemble everything to reconnect the joint.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 03-20-2011, 04:08 PM
antoniodef's Avatar
Member #11247
Still waiting for my freakin springs. Does anyone know what you torque the nuts on top of the springs too?
Old 03-22-2011, 09:24 PM
antoniodef's Avatar
Member #11247
The springs actually came with directions...15ft/lb
Old 11-08-2011, 07:28 AM
Marty124's Avatar
Member #7273
dang, just found a thread from another forum that shows it pretty well...
polaris hd springs installed - atvconnection.com atv enthusiast community
i vote this post become a sticky thread... Great information.
2010 SPORTSMAN 500 H.O.
2011 polaris sportsman remove springs
how to compress a atv shock spring to reinstall
how to compress atv shocks
how to compress atv spring
how to compress atv springs
how to compress spring on sportsman 400?
how to compress the rear springs on a sportsman 500
how to install atv front springs
how to install polaris shocks
how to install the pull starter spring on a polaris sportsman 500
how to replace polaris sportsman shock springs
polarishdspringsinstalled
torque of front springs on polaris sportsman
verticak\l enging gove\oner
Winch Install: 2011 sportsman 500 (w/ pics) Fotayfive Polaris Sportsman 33 04-06-2012 05:19 PM
2011 sportsman 500 pure polaris winch install help!! CarFanatic Polaris Sportsman 28 02-12-2012 06:27 PM
2011 500 winch install indybear54 Polaris Sportsman 48 09-06-2011 05:03 PM
2011 sportsman 500 winch install hunterboy ATV General Discussion 4 02-20-2011 06:40 AM
help! broke spring oil pump spring! 96xpress400 ATV Repair and Maintenance 3 11-30-2010 07:35 AM
