Old 03-16-2011, 02:00 AM
buckwild kid's Avatar
Member #12643
weird front brakes
I have an '03 Predator and have a question on the front brakes. Some times I have to pump the front brakes once or twice to get an acceptable pressure "feel" to the lever when stopping. When moving and you pull the front brake lever the lever pulsates. What would cause that? (It doesn't matter if you are going slow or fast when it pulsates btw.)
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
Old 03-16-2011, 02:52 AM
Muskyhunter's Avatar
Member #12128
The pulsating that you're feeling is because your one or both of your discs are likely warped. If they are warped enough they can push the pads back in to the caliper resulting in you having to pump the brakes. Or, you also have air in the system which is making it spongy.
Old 03-16-2011, 03:03 AM
Member #12643
I kind of figured that there might be some air in the lines, but the weird thing about that is that it doesn't always do that. As far as the warped rotors, that is not what I was hoping to hear... $$$
03 predator 500 front brakes
2003 polaris predator fmf full exhaust
96 polaris xploroer spongy front brake
atv brakes spongy
atv front brake lever for polaris predator
atv front brakes are spongy
front brakes polaris predator
polaris atv front brakes
polaris front brake not stopping atv
polaris front brakes
polaris predator 500 front brake handle
polaris predator brake spongy
polaris predator front brakes
polaris sportsman front brake spongey
spongy brakes on polaris atv
what brakes fit a polaris predator front
front brakes hang up redhammer082 Polaris Predator 2 10-22-2010 02:29 PM
2010 550xp front brakes and ball joints michaeltucker01 ATV Brakes & Suspension 12 09-27-2010 03:57 AM
separate front and rear brakes? fatkidracer ATV Brakes & Suspension 7 07-12-2010 04:47 AM
96 sportsman 400 FRONT brakes Reflexx85 ATV Brakes & Suspension 3 05-24-2010 12:52 AM
00 polaris xplorer 300 4x4 front brakes slammed95 ATV Brakes & Suspension 2 04-20-2010 07:57 PM
