Old 03-20-2011, 03:27 PM
halfa12pk's Avatar
Member #11938
Send a message via AIM to halfa12pk
brake caliper
i am working on my 05 800 sportsman i have a stripped bleeder on the rear caliper. it is the caliper thats stripped not the bleeder. any ideas on a cheap fix? or just bite the bullet and spend the 200 for a new one?
Old 03-22-2011, 07:08 AM
jjjbluray's Avatar
Member #12554
How do you know which part is stripped? I purchased my 05 Magnum 4x4 from a guy that had it serviced and was told the "brake pad housing needed replacing because the threads for the bleeder screw pulled out". Sounds Hebrew to me. I put a socket on it and it loosened like it was supposed to and brake fluid came out. Good luck with yours. My foot pedal still doesnt work.
Old 03-22-2011, 05:27 PM
halfa12pk's Avatar
Member #11938
my bleeder wont tighten up and if you look in the hole the threads are gone they come out with the bleeder. i ordered a new one today, 200 dollars later it will be here in 3 to 5 days
Old 04-28-2011, 06:35 AM
stewb73's Avatar
Member #12047
Send a message via MSN to stewb73 Send a message via Skype™ to stewb73
Try tapping it out and then put plumbers tape on the bleeder screw. Worked for me.
Old 05-08-2011, 01:15 PM
tester1a's Avatar
Member #14401
I second halfa12pk's solution, tap it and tape it...
Old 05-26-2011, 12:59 AM
Brett6680's Avatar
Member #15401
The brake caliper is the assembly which houses the brake pads and pistons. The pistons are usually made of aluminum or chrome-plated steel. There are two types of calipers: floating or fixed. A fixed caliper does not move relative to the disc and is, thus, less tolerant of disc imperfections. It uses one or more single or pairs of opposing pistons to clamp from each side of the disc, and is more complex and expensive than a floating caliper. A floating caliper (also called a "sliding caliper") moves with respect to the disc, along a line parallel to the axis of rotation of the disc; a piston on one side of the disc pushes the inner brake pad until it makes contact with the braking surface, then pulls the caliper body with the outer brake pad so pressure is applied to both sides of the disc.
Thanks,
mini tripod
slik tripod
Old 06-04-2011, 10:14 PM
woodrock23's Avatar
Member #14846
Well, sometimes nothing goes right on a beautiful day for riding. Seems a small leak developed for the braking system. I have bled brakes before so I know a bit how much pressure to put on the wrench for the bleeder. My main question, you suggested to tap it out and put plumbers tape on the bleeder. What size are the threads? I tried tapping it out with a 1/4 by 28 tap but the bleeder weeps anyway. Is it possible to use a larger tap and use the bleeder to match those new threads? Do you know what size is best as I really don't want to purchase a new capiler. thanks for reading
atv brake caliper moves
atv caliper bleeder screw repair
bleed stripped atv
brake fluid for a polaris atv
caliper bleeder stripped
how to bleed rear brakes on polaris predator
how to fix a stripped caliper bleeder screw atv
how to fix striped out caliper bleeder hole
is a polaris magnum 330 caliper fixable
polais atv caliper bleeder stripped
polaris 800 rear caliper forum
polaris atv brake caliper
polaris caliper bleeder screw strip
polaris magnum brake caliper
polaris sportsman brake bleeder valves leak
polaris sportsman rear caliper bleeder stripped
sportsman bleeder stripped
stripped bleeder screw polaris atv
stripped brake bleeder on polaris atv
stripped threads on brake bleeder on polaris
03 magnum 330 brake caliper needed kavetskilp Polaris Magnum 3 01-30-2011 10:10 PM
1992 350 4x4 frt brake caliper removal Big Rich ATV Repair and Maintenance 4 01-28-2011 11:30 AM
Brake Caliper compatability JohnBrison Polaris Sportsman 3 11-21-2010 06:17 PM
Rear Brake Caliper phillipnorton Polaris Predator 9 10-14-2010 06:18 PM
rear brake caliper bomberboat ATV Brakes & Suspension 5 07-27-2010 01:18 PM
