03-23-2011, 08:29 AM
Member #12726
sportsman 700 Brakes hanging up?
I just put all new brake pads in my 2002 sportsman 700. All calipers compressed, cleaned and greased slide pins. I have noticed when i give it gas to start off it feels like brakes are on just a little bit and quad is working harder...or could this be a worn drive belt?
03-23-2011, 08:55 AM
Member #5629
Did you remove the master cylinder cover when you compressed the calipers?
Watch the engagement rpm to see if it is above the reccomended value. If so then check the belt.
Con
03-23-2011, 09:12 AM
Member #12726
Yes . I did remove master covers. What rpm amd what am I looking for...Mike
03-23-2011, 09:19 AM
Member #5629
Have you tried bleeding the brakes? Not real sure. It should be about 400-600 rpm above idle.
Con
02 sportsman 700 changing rear brake, 2002 polaris 700 transmission fixes, 2002 polaris sportsman 700 front brake master cyclinder, 2002 polaris sportsman brake pads, atv new brake pads caliper hanging up, brakes on sportsman 700, changing rear brake pads on sportsman 700, how to change brakes on 800 sportsman, how to change front brakes polaris 800, how to fix rear brakes on 800 sportsman, how to get front brake pads off polaris 700, p olaris sportsman brakes off the gas, polaris 700 sportsman brakes, polaris iq brakes hanging up, polaris sportsman 700 brakes, polaris sportsman 700 when to replace drive belt, polaris wheel hanging, replace brake pads sportsman 700, replacing front brake pads 2002 polaris 700 sportsman 700, what brake pads to use on polaris 700 sportsman
