04-09-2011, 06:09 AM
Member #13811
Spring Wrench
Is there a wrench that I should use to turn up my rear springs. It seems really hard to do by hand. I bought my wheeler used so I didnt get anything.
04-09-2011, 07:38 AM
Member #5629
Welcome!
When I turned my springs up, I removed the tire, sprayed the adjuster with wd 40, let it sit a few minutes, then I used a pair of large channellock pliers. Watch that you grip the adjuster at the proper place(just under the spring, not where the slots are). By having the suspension at full extension will help a lot!!
Con
04-09-2011, 08:37 AM
Member #7044
Do what racer says with wd-40 and jacking up the machine.
My channellocks weren't quite big enough & had to use a pipe
wrench the first time.
I came across a Fram filter wrench at WalMart that looked like it
would work, it does and for about $5.00.
Take care,
Scott Deeter
04-09-2011, 10:50 AM
Welcome!!
While both suggested methods work what you need is a spanner wrench it comes with most machines and is also avaliblemat your dealer. I got a couple off eBay too
04-19-2011, 07:05 PM
Member #12530
I just did the suspension adjustment tonight. Removed the tire sprayed th e shocks with wd40 and used channel locks to adjust. Mine have never been adusted so it took a little torque to get them to move initially. My question would be how do you get them back down after you turn them up. Doesn't look like it would be very easy.
05' Polaris Sportsman 700EFI  - 3 Headlight Mod
- 2500# Warn winch
- 55" Moose Plow
04-19-2011, 10:35 PM
Member #4452
Turning them back down is easier
Sent from my DROIDX using Tapatalk
2000 polaris spanner spring wrench, 2010 polaris sportsman suspension wrench, a spring wrench, atv spring wrench, fourwheeler back spring wrench, polaris 4 wheeler shock wrench, polaris atv rear shock wrench, polaris atv shock spring tool, polaris spring wrench, shock spring wrench, spring wrench, spring wrench for suspension, spring wrench', spring wrenh for polaris, what is a spring wrench
