Old 04-13-2011, 10:38 AM
1999Sport400's Avatar
Member #12722
how to bleed brakes
can anyone tell me how to bleed the brakes on my 1999 polaris sport 400
Old 04-13-2011, 10:40 AM
Are you familiar with bleeding brakes at all? How much detail do we need to go into?
Old 04-13-2011, 10:42 AM
Member #12722
i tried bleeding them the same way i would a normal vehicle, ive never had a prob before bleeding brakes
Old 04-13-2011, 05:22 PM
7.62Addict's Avatar
Member #13356
How are you bleeding them, and does your machine have the seperate rear master? It takes two people to do it correctly unless you are using a vac bleeder. If your using a vac bleeder you will need to apply some teflon tape to the bleeders to make sure no air gets in. If your using the pump and hold method just make sure you go slow and allow a few seconds between bleeds and keep the master full. Its important to not bottom out the master when bleeding, it can cause premature failure of the master. You probably already know, but start in the rear and work your way forward doing the calipers farthest from the master first.
Old 04-13-2011, 05:29 PM
Member #12722
yes i have a separate rear master and i cancelled the line from my front master to rear caliper. i dont have a vac bleeder and the pump and hold method doesnt seem to b workin, im almost thinkin my front master is no good, cuz ive bled brakes before and never had this kind of problem
Old 04-13-2011, 05:32 PM
7.62Addict's Avatar
Member #13356
What problem are you speaking of? Are you not getting fluid out?
Old 04-13-2011, 05:33 PM
Member #12722
ya im not gettin ne fluid but when i press on the brake handle i can hear it pushing air out and sucking it in
Old 04-13-2011, 05:36 PM
7.62Addict's Avatar
Member #13356
Did the master run dry? If it did, you can try bleeding just the master. If you still cant get fluid to flow, replace it. I had to replace mine on my 01 because I had no pedal so to speak and I lost brakes.
Old 04-13-2011, 05:39 PM
Member #12722
it never ran dry but it sat for 10yrs, i dissasembled everything, flushed the lines and calipers, even took the reservoir off the master and cleaned all of that out, and before attaching the brake line to the master i filled it with fluid and i wasnt getting nething, but when i stick my finger on the output it pushes out and sucks in, like i said this is weird
Old 04-13-2011, 05:41 PM
7.62Addict's Avatar
Member #13356
What did you clean and flush it with?
1999 scrambler polaris 400 brake bleeding
bleeding atv brakes
bleeding brakes on polaris atv
bleeding polaris atv brakes
bleeding rear atv brakes
cant get my polaris atv to bleed the brakes
how do i change the brakes on my 99 polaris sport 400?
how to bleed 1999 polaris brakes
how to bleed atv brake lines
how to bleed atv brakes
how to bleed atv rear brake
how to bleed brake lines on atv
how to bleed brakes on a atv
how to bleed brakes on a polaris atv
how to bleed brakes on a polaris scrambler
how to bleed brakes on atv
how to bleed brakes on polaris atv
how to bleed polaris atv brakes
how to bleed polaris atv rear brakes
how to bleed the back brakes on an atv
I bleed green but I bought an Outlaw anyway.. ScottieD Polaris Outlaw 7 02-03-2011 11:20 AM
Scrambler radiator bleed? thebode11 ATV Repair and Maintenance 0 10-15-2010 07:11 AM
1994 400L 4x4 Brake Bleed issues Nondem ATV Brakes & Suspension 7 06-15-2010 10:52 AM
brakes on 09 xp 550 kohen ATV Brakes & Suspension 2 05-03-2010 04:28 PM
how to bleed brakes on a polaris scrambler triefff ATV Repair and Maintenance 3 04-04-2010 08:05 PM
