Old 04-20-2011, 09:47 AM
Pawnee's Avatar
Member #14214
Unhappy Steering Problems
On two or three occasions my 04 Sportsman 500 has taken an unexpected hard right or left while riding straight, difficult to steer forward until it breaks loose; the rest of the time the steering has been okay.
Old 04-20-2011, 09:23 PM
Old 04-20-2011, 09:25 PM
black sparrow's Avatar
Member #11979
Have you cheked your front brakes? It could happen if one side or the other is locking... my 2 cents.
"To EaCh hIs oWn"
Old 04-21-2011, 03:50 AM
Diesel man 03's Avatar
Member #7294
Brakes could be binding on one wheel but most likely one of the front axles is engaging onto 4 wheel drive.
Old 04-21-2011, 04:16 AM
josh's Avatar
Member #4417
it sounds to me like a axle or hub. i have had the cv joints do that before they get ready to let loose.
Old 04-21-2011, 04:49 PM
weedy's Avatar
Member #2147
Sounds like the Hillard clutches engaging on one wheel inadvertantly. Change hub oil.
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
Old 04-21-2011, 05:49 PM
chopper89's Avatar
Member #1634
welcome to the forum, check brakes first thats the easiest then if good i would change the front diff oil , just the way i would go easy stuff first
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 04-21-2011, 07:21 PM
Member #1958
Change oil in the hubs and see if that helps. You likely have problems with one of the hilliards in the hub not disengaging correctly. Get all 4's off the ground. Turn the 4x4 on and run it then turn it off and run it. One of them probably won't disengage while the other will. Changing oil might make it better or you may have to go into it. Those models with hilliards in the hubs can be finicky but are not that hard to fix.
04 predator steering issue
2004 polaris steering problems
2005 polaris sportsman 500 steering
99 polaris atv steering problem
atv steering binds
my steering wheel is loose on my polaris sportsmann 500
polaris 500 right brake grabbing
polaris 90 turning problems
polaris atv steering defects
polaris atv steering problems
polaris atv sterring problems
polaris predator 500 steering problem
polaris predator steering
polaris predator steering problem
polaris sportsman 500 steering binding
polaris sportsman 500 steering problems
polaris sportsman steering pulls
sportsman 500 steering pulls
steering loose on 500 polaris sportsman
steering problems with atv
Help with Steering set up Danco411 Polaris Predator 6 04-18-2011 10:50 AM
trouble with steering l-rod Polaris Sportsman 11 11-09-2010 04:35 PM
'99 Explorer steering problems bdcrodc ATV Brakes & Suspension 4 10-29-2010 06:26 AM
xp steering sjcarp ATV General Discussion 10 09-10-2010 04:05 AM
2009 850 xp eps steering problems bobwhitecar ATV New Members 2 12-12-2009 07:48 AM
