Old 04-23-2011, 09:45 AM
905mikey's Avatar
Member #14064
cv joint/ axle length/ liftkits/ HELP !
just installed 1.5" lift on my 04 sportsman 600, worked good first run out, but ended up pulling a cv joint apart in front wheel, is this common with lift kits cause the suspension is reaching further, do I need longer axle shafts or lengthen mine ? The cv joint is still in the boot didn't even rip the boot that's what makes me think length issues ? Please help ! Thanx
Old 04-23-2011, 11:18 AM
racer37l's Avatar
Member #5629
The length of the axle should be good for a 1.5" lift. I've been using stock axles with a RDC 2" lift for almost a year now and no problems.
One thing to look at would be the c-clip on the axle As maybe it has become weak over the years.
Or possibly just a broken joint in the boot.
Con
Old 04-23-2011, 01:25 PM
905mikey's Avatar
Member #14064
Ok thanx but it pulled the 3balls out with the axle as a unit, so the clip held, still thinkn length issues, what if I cut the axles and weld a tube over the joint with an inch extra length ?
Old 04-23-2011, 06:00 PM
racer37l's Avatar
Member #5629
What lift kit are you using?
Did you check the cage that the balls sit inside?
Con
Old 04-24-2011, 07:08 AM
905mikey's Avatar
Member #14064
Its a highlifter lift kit, just strut spacers and coil spring spacers on front, have got the axle out yet, just by feel, cus the boots not ripped, I can feel the 3balls still attached to the main axle shaft as a unit, will get it out and apart this week, thanx so far !
Old 05-03-2011, 01:42 PM
MUDDIE49's Avatar
Member #858
I agree you should'nt have any problems with the axles...I installed a similar kit and i did'nt have any problems even with going up a size on the tires and wheels..problay just a feaky thing that happened.Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
2011 polaris sportsman 800 lift kit axle problem
2011 sportsman 800 3 in lift , axles
2in lift kits 09 polaris sportsman 800
adrenalin 3in lift cv axles problems
atv axel lenght
atv axle
atv extended length cv boots polaris sportsman lifted
atv lift kit cv clicking
axle shafts off of a 2010 sportsman 800 the same lengths as the 2011 sportsman
cv axle length
does a lift kit break cv axels
length of stock axle for polaris xp
lifted atv axle boots
polaris 500 ho lifted
polaris max lift with stock axles
polaris sportsman 2'' lift axle coming out
polaris sportsman lift kit broke cv joint
what makes up a cv joint
why cv axle spacers
will a two inch lift damage my atv
U-joint style rear axle removal Diesel Polaris Sportsman 5 11-28-2011 09:51 AM
Length of XP Touring River Hill Polaris XP 3 04-05-2011 07:02 PM
Stud length change between 09 and 11? bronco ATV Wheels & Tires 0 11-22-2010 10:23 PM
Gorilla axle cv joint question tufzuk ATV Repair and Maintenance 1 07-25-2010 08:14 AM
2000 front axle u-joint converted to cv chromejunks Polaris Sportsman 2 09-04-2009 02:07 AM
