Old 04-25-2011, 09:18 PM
forrest411's Avatar
Member #13482
2002 Sportsman 2" coil spring spacer/strut plug
My front end is sagging down. I wanted to put a 2" coil spring spacer between the strut housing and the spring and add a 1.5" strut plug in the bottom of the strut housing. When I took the shocks out of the strut housing they where already 1.25" from the bottom of the strut housing.
Here's the question: Is the shock supposed to go all the way to the bottom of the strut housing or not? The manual just says to scribe a line before disassembly (which I did). But if I put a 1.5" plug is will only raise the strut a 1/4in. from where it was at originally.
My goal is to raise up the front end to be level with the rear. I'm not looking to run bigger tires, but I do have a winch on the front which is causing the sag.
Thanks for you help in advance!
Old 04-26-2011, 01:17 AM
cwlongshot's Avatar
My personal opinion is do it once and do it right... I suggest you buy HD springs and or buy a "lift" kit.
Old 04-26-2011, 03:52 AM
SMP63's Avatar
Member #13545
^^^^^^^^^ I agree with CW! Thinking about HD springs for mine.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 04-26-2011, 04:21 AM
weedy's Avatar
Member #2147
Do the stock HD spring have a harsh ride? My 2005 front endis a little soft and sags slightly (I think because of the additional weight of a winch monted on the front).
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
2005 polaris sportsman 500 coil spring spacer
atv coil spring spacer
atv front spring spacer
atv shock spacers
atv spring spacer
atv spring spacers
coil spring spacers 2002 spotsman 400
front coil spring spacers for my 2012 polaris sportsman 500 ho
homemade sportsman 500 strut plug
polaris coil spring spacer kits
polaris coil spring spacers
polaris sportsman aluminum spring spacer
polaris sportsman spring spacers
polaris sportsman strut plugs
polaris spring spacer
polaris spring spacers
polaris strut lift
polaris strut spacer
sportsman front spring spacers
strut spring spacers
2002 Sportsman 700 Twin "No Spark" tarzy ATV Repair and Maintenance 3 09-19-2011 03:02 PM
Spacer Answer 09 Sportsman 500 4x4 EFI w/ pics renocoyote ATV Wheels & Tires 9 06-05-2011 03:32 PM
spring "cleanup" MNPolaris850XPeps Polaris XP 5 04-11-2011 06:34 PM
Polaris sportsman atv strut and spring Super ATV ATV Parts for Sale 0 11-29-2010 06:56 AM
homemade front spring spacer bakada ATV Brakes & Suspension 13 07-25-2010 09:15 PM
