Old 05-02-2011, 02:51 AM
kool_500HO's Avatar
Member #11710
Adjusting rear springs, Any adverse effects?
Besides a stiffer ride and everything, will the higher setting of the rear sprins cause any adverse effects? Like less suspension travel? tires not staying in touch with ground as much over ruff terrain (articulation)?
2011 Polaris Sportsman 500 HO
6000K HID's,Kimpex fender guards,foot pegs,rear seat,Polaris Front/Rear bumpers,2500lb winch,Handguards,ITP SS 12" 212 machined wheels,ITP Mudlite XL 26" tires,Highlifter springs Front/Rear,26" Outlaws,QSC clutch kit/Exhaust,UNI filter,Ricochet A-Arm guards...More coming soon...Kinda running out of stuff to buy though!
Old 05-02-2011, 08:54 AM
SMP63's Avatar
Member #13545
How's it going Kool? All the adjust does is preload the springs. It does not affect the travel of the suspenion. I adjusted mine up 2 notches when installing a-arm guards & i like the ride better now! Make sure you jack it up &
remove tires when adjusting, makes it easier to turn adjuster ring!!!
Hope this helps!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 05-02-2011, 09:05 AM
kool_500HO's Avatar
Member #11710
Cool stuff, just some other sites said that jacking up the rear would effect suspension travel and them being so stiff would not be in contact with the ground as well going over ruff terrain then they would if they were at their softest.
Old 05-02-2011, 09:52 AM
scottdeet's Avatar
Member #7044
For conversation sake, I would think jacking up the suspension would
make it have less travel. Simply for the reason it now takes a greater
force to compress the spring. Of course this all depends on the riders
weight to setting ratio.
Regarding ground contact, with the sportsman being independent
suspension, set at a higher ratio it would force each wheel into the ground
so to say on uneven terrain. Does this make sense in a way?
Take care,
Scott Deeter
Old 05-02-2011, 10:07 AM
cwlongshot's Avatar
Talking
Don't over analyze this!!!! It's a simple adjustment. If it feels soft or wallows or bottoms out make it stiffer.
Hows this...If the springs are sagging and you stiffen them you will a tually raise the machine. By raising the machine you will also actually be gaining suspension travel that was lost by the sagging springs....
Conserning ground contact with a stiff vs solt suspentio in a ATV... In a back and white world I'm certaintherr will be a difference. Here in reality I gaurenty you will not see, feel or otherwise know it exists.
As I said it's a simple adjustment. Just do it. If you don't like it you can always return it to it's original setting....
1998 polaris sportsman sagging
adjusting the spings polaris 400ho
adjusting the springs on a polais 500 ho sportsman
atv spring adjustment tool
how to adjust back springs on a 2000 polaris
how to adjust polaris ranger springs
how to adjust rear spring on polaris 500 ho
how to adjust shocks 2010 sportsman 500
how to adjust springs on a polaris
how to adjust the springs on a polaris ranger
polaris ranger spring adjustment
polaris ranger suspension adjustment
polaris rear spring adjust
polaris sportsman 700 shock adjusting ring
polaris sportsman rear springs
ranger 400 rear springs
rear spring adjustment on polaris
rear spring adjustment polaris ranger
to adjust atv back spring
Rear springs with HD fronts antoniodef ATV Brakes & Suspension 2 03-31-2011 04:29 PM
X2 Rear Springs CrewCabMax ATV Parts for Sale 0 10-18-2010 06:39 PM
X2 Rear Springs CrewCabMax ATV Brakes & Suspension 0 10-18-2010 06:38 PM
rear springs SAWFILER55 Polaris Sportsman 1 05-02-2010 09:47 AM
96 sportsman 500 rear springs & shocks firedude26 ATV Repair and Maintenance 3 11-20-2009 02:12 PM
