05-06-2011, 05:06 PM
Member #13773
Brake pads and rotors shot after 10hrs???
Any one ever heard of brake pads and rotors shot after 10 hrs on a bike?...my buddy's 850 bought the same day brought to service the same day, He also has to replace his brake pads at 22 hrs...
my cost $230
his cost $110
Is this common to go threw brake pads this quick?
And Polaris assumes no financial responsibility AT ALL(nice warranty)
The dealer said he called them to get some money for the repair(since its only 10 hrs old) and they refused.."said it was a disposable part" I thought I had a 6 month warranty against defects...
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
05-06-2011, 05:18 PM
Member #5254
Brake pads are not usually are not covered regardless of manufacturer.
Sent from my iPod Touch using Tapatalk, as if anybody actually gave a sh!t if it was a desktop, laptop, crackberry, I-phone or freakin' morse code or for that matter smoke signals...
Thanks,
Will
2004 GMC 1500CC Z71.
05-06-2011, 06:01 PM
Member #7294
Brake pads and rotors are not covered by warranty but with 10 hrs there must be some kind of problems.
05-06-2011, 06:08 PM
Member #5254
my cost $230
his cost $110
Are you riding in mud and water??
Thanks,
Will
05-06-2011, 06:40 PM
Member #13773
my cost $230
his cost $110
Absolutely,I thought that's what these machines were built for,It has been power washed after every use and I drive it threw the fields after to dry the brakes...
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
05-06-2011, 06:50 PM
Member #13773
[QUOTE=Diesel man 03;94049]Brake pads and rotors are not covered by warranty but with 10 hrs there must be some kind of problems.[/QUOATE}
That is exactly my grievance, for a bikes brake pads to wear out and then damage the rotor all within 10 hrs...I would think there was something wrong right from the get go..and the dealer agreed with me but Polaris shut'em down..my problem not there's.
I understand the warranty doesn't cover pads and rotors, If this happened a couple months in..I wouldn't think twice about it..its just the fact that it happened so soon and on 2 separate bikes from the same dealer.. such low hrs and usage.
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
05-07-2011, 03:46 AM
Member #4775
Something is not right. For one thing, with engine braking and active decent, I hardly use my breaks on my 850. But even so these things are engineered to last for thougsnds of miles. Even with abusive riding I can't see going through stuff this fast. The 850 is so powerful that one might not notice if the breaks are dragging. Something is just not right. JB
05-08-2011, 01:13 PM
Member #14401
break pads wearing quickly
I took my 550 apart for another reason and found that all three sets of pads were completely gone, about 400 miles on the bike. I have been riding with Active Decent turned off, in the future I will try to leave it on and see if the wear improves.
I have also noticed that with this particular break design that the pads are free floating and always touching the rotor. I am not a break specialist by any means but I think that would lend itself to greater wear. I will research and see if there are any after market breaks for my 550 with better wear characteristics.
05-08-2011, 02:44 PM
Member #5254
EBC Severe Duty??
Thanks,
Will
05-08-2011, 02:49 PM
Member #13725
It is possible to have brake drag by over filling the master cylinder reservoir, brake fluid heats up and expands if reservoir is full pressure will cause brakes to drag. Also muddy conditions can wear pads out faster, if you are driving in mud a lot I would look for aftermarket pads and maybe solid rotors made for mud conditions. As for riding with ADC on all the time I understand this cause the friction material in ADC to wear out in a short time.
1999 polaris xplorer 300 how to change brake pads, 2011 polaris ranger 800 xp brake pad replacement, change rear breaks polaris predator 90, changing back pads on 2001 trail blazer, changing brakes on a 2001 polaris 4 wheeler, how to change brake pads on a 2010 sportsman 500 ho touring, how to change brake pads on a 4 wheeler, how to change brakes on 2001 polaris xplorer 400, how to change brakes on a 2001 polaris sportsman 500, how to change rear brakes on a 04 sportsman, how to change the rear brake pads on a polaris 400 explorer, how to install break pads on polaris predator, how to put brakes on a polaris four wheeler, how to replace brake pads on polaris xplorer 400, polaris 2001 sportsman 500 brake pads, polaris 550 defective brakes, polaris scrambler 400 rear brake pads wear out too fast, polaris trailblazer brakes rotors, polaris xplorer 400 front brake pad removal, rotors shot
